Question about Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower won't start
I'm having difficulting starting this snowblower, it is a 5 horsepower tecumseh engine. I,m using the manual crank because the electric start stopped working.Model932006 Serial 003611
  • 21 Answers
SOURCE: need a copy of owners manual for ariens st5+2
try tradebit.com they should have what you need
Posted on Jul 29, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
rwvanlue
  • 486 Answers
SOURCE: How much oil is in an Ariens 5 hp snowblower ?
5 hp should have 20 oz.
When checking,
1) fill the oil to top of threads (if the inspection cap is threaded into the side of the block close to the bottom)
2) if it has a dipstick, wipe the stick as you remove it, re-insert *do not screw it down, just allow it to set on top of dipstick housing.
*note: you cannot overfill unit on an inspection cap
*** you CAN overfill on a dipstick. Any more than 22-24 oz, the engine will blow it out the valve cover breather hole.
Posted on Nov 12, 2009
Testimonial: "Quick,accurate response --- thanks"
wireguy212
  • 1627 Answers
SOURCE: ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Posted on Feb 17, 2010
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
Using ariens snowblower today, model# 924026 and heard a ping and everything stopped. Tecumseh engine model3 H80 155006. Some white smoke came out and some oil leaked down side of metal part that oil is...
Check your compression tecumseh's are known for the exhaust valve seat poping out of the head. If you have compression check the governor shaft it should only turn about a 1/4 turn.
Dec 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Is Ariens ST 270 a 2 stroke or 4 stroke engine?
It is a 4 stroke engine made by Tecumseh. It is 2.7 horsepower, but I don't know the model # of the engine itself. Try going to Ariens website. With a little digging around, you should be able to get a manual from them that shows all the parts. Also try finding an Ariens dealer near you. They should be able to find and order parts.
Nov 19, 2010 | Sport & Outdoor - Others
I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Sep 22, 2009 | Garden
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Ariens 34 In. Zoom Series Riding Mower Logo
781 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
