Question about Ovens
Bakers pride y600 top oven lights only when bottom oven is hot.
The pilot light is lit and burns fine,however i cannot get the burner tubes to stay lit. Upon turning on the gas valve the tubes light initially for about 15 seconds and go out(it is a weak flame at best). However after the bottom oven has reached operating temp. i am able to turn the top oven on usually with no problem. I recently replaced the gas valve about 5 months ago and had no problems until about a month ago. Any insight would be helpful.
  • Ovens Master
  • 19,396 Answers
You need to test and eventually replace either the valve or the thermocouple that controls the valve.
You find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Top heat control damper is faulty check it.
Posted on Jan 15, 2009
  • Rylee Smith
    Rylee Smith Jan 15, 2009
    Your oven model is using spark ignition system which uses a pilot to light but it is not lit all the time. When your oven thermostat is turned on, gas flows to the oven burner safety valve and also the oven's pilot which gets lit via a spark. Once the pilot is lit and the oven safety valve's sensor bulb senses it, that valve will then open to allow gas to flow to the oven burner where the pilot flame ignites the burner.
    But, here your sensor (in top deck) is sensing it only after 30 sec.s or when bottom one gets heated up. So, you need to replace your sensor or check for any unusual stuff around the sensor.
    Genius:
  • 2,920 Answers
You can take the burner tubes out and clean them really well with a tooth brush or a soft wire brush to help them stay lit...i had yo do it on my stove cause it wouldnt stay lit
  • Ovens Master
  • 4,806 Answers
Hi there
It sounds like the burners themselves are in need of a damn good clean as soot and other debris could be blocking the jets causing the malfunction. What you need to do is remove them and clean all the inlet/outlet pipes and the burners themselves either by yourself or a professional ( professional is recommended as messing with gas appliances could prove dangerous )
Good luck and thanks for using Fixya
    Master:
  • 416 Answers
It might be that burner is cloggged with grease. When it warms up grease will evaporate or melt and gas flow increases. Try to use grease cleaner for ovens. Or replace the burner
Good Luck
    Top Expert:
  • Ovens Master
  • 77,499 Answers
I would replace the oven temp probe, this sends the signal to the gas valve to open and close, i am sure that is the problem.
Put in new valve and thermal couple but pilot stays lit , but when thermostat is turned on everything blows out after a few minutes
Check your exhaust does the flame on the burner look like it is starting to float after a few minutes if so you are starving for secondary air
Feb 01, 2014 | Bakers Pride Y-600 Gas Single Oven
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
I ran out of propane...so now truck is filling us up..how do I get the oven working again..how to light the pilot light?
Hi there, hope this helps. On the front of the oven, usually on the left side, where your thermostat is, has a red button sticking out, that is your pilot safety. To light it, you need to open the lower door, and aprox. in the center of the area, is your pilot, has a small pipe going to it, you have to hold the red button in, and light the pilot in that lower chamber, and most of the time, once the pilot is lit, you must hold the button for 60 to 90 seconds. If it does not stay lit when you let go of tthe button, you may have additional problems, let us know. And thank you.
Feb 20, 2009 | Bakers Pride Y-600 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
WAISTING GAS BAKERS PRIDE GAS OVEN DOESNT SHUT OFF
Hi, don't know if you received an answer, however your gas valve sounds to be bad, when turned to pilot, it should only allow gas to the pilot assy. The problem is, it has already failed to shut fully, if it still does that with it in the off position, it would still be allowing gas through it, if the pilot goes out, there is now no protection to shut itself off, get it replaced ASAP. Hope that helps, and thank you.
Sep 28, 2008 | Bakers Pride C011-E2-C Gas Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
