Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Changed gear box in craftsman garage door opener
No garage door closes and then goes back up. Made several adjustments but no luck. Help
    Champion:
  • 244 Answers
You did not give enough info. If it closes completely and right away goes up, if bulb blinking. if it is, something on door is blocking safety beam. If light is not blinking, DECREASE down travel.
Posted on Jan 15, 2009
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
Craftsman 1/2 hp garage door opener will start to close and after 2-3 seconds it goes back up and there is no obstruction blocking sensors
you may need to adjust limit switches in back of operator.Most of the time with this problem one of the gears inside the operator has stripped out.
Jan 26, 2013 | Sears Craftsman LiftMaster Chamberlain...
The garage door closes and then opens up again, I have to close it several times before it secures. There are no obstructions. Is this a sensitivity problem?
More than one thing can cause this type problem.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is not flickering ever so slightly.
If the door reverses when it hits the floor it is a sign that the door is traveling a bit to far. The adjustment for this is on the side of the motor unit. Turn the 'down limit' in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
We just replaced a broken spring (re[laced both sides) on craftsman garage door opener and now the door won't shut all the way. It goes down to about 12" from closing and then goes back up.
YOU COULD HAVE THE WRONG SPRING OR NOT ADJUSTED PROPERLY. YOU COULD HAVE AN OPERATOR ADJUSTMENT PROBLEM.
HOW DOES THE DOOR WORK MANUALLY??
IF IT IS HARD TO PUSH DOWN AT THE BOTTOM - SPRING PROBLEM - IF IT WORKS AND CLOSES VERY SMOOTHLU AND EASILY THEN YOU COULD ADJUST THE DOWN SENSITIVITY - JUST A LITTLE.
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My crafstman garage door opener goes down and then
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 2 feet and then closes in same cycle
There is an issue with the limit settings. They are the three white screws you can see with the cover off. Put the door in the down position. take the small white piece off the bottom of the gear and sprocket assembly. Turn the center screw until the silver "wing" is at the bottom position. Put the white piece back on the bottom of the gear and sprocket. Adjust the up screw until the door opens fully. Check the force settings. They both should be set on 4-5.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't shut after changing gears
if you changed gears, you may have chain out of sync. read instructions with gear kit on how to sync chain.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener
IF IT HITS THE FLOOR AND GOES BACK UP. YOU NEED TO ADJUST THE DOWN LIMIT.
IF IT GOES BACK UP BEFORE HITTING THE FLOOR YOU NEED TO ADJUST THE SENSITIVITY OR THE SAFETY EYES.
TRY THE DOOR MANUALLY AND MAKE SURE IT WORKS SMOOTHLY.
Sep 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
134 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
