Question about Garmin StreetPilot C330 GPS Receiver
Backup Streetpilot C330
I own a streetpilot C330 which has 2006 maps info. I now want to upgrade it to 2009 map update. Is there a way to backup the maps which are currently present on my GPS?
I don't see any separate USB drive icon when I hook up my GPS to my laptop
  • 20 Answers
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Posted on Jan 20, 2009
  • 3 Answers
I found out the solution for this ... the trick is using mapsource.. I didnot get the mapsource CD with my streetpilot unfortunately... hence the question.
Thanks for all the help...
Posted on Jan 16, 2009
My Garmin Streetpilot c330 is not reading/finding the sd card
If the SD card are maps.
go to tools, maps, map info,
tick the boxes
you will need serial number on the sticker on the bottom
and unit I.D. in your tools, system, about, it is located
Regards
Richard
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Tip
Upgrade for C330 on Garmin site
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=StreetPilot%20c330
has upgrade for your garmin that solved the slow satelite fix for me, has a list of many other issues that it corrected in the new update programing ..
no need to upgrade maps for this update.
on Sep 12, 2008 | Garmin StreetPilot C330 GPS Receiver
How do I upload Maps update for Streetpilot c330.
Installation Instructions
  1. Download the self-extracting archive file for your Streetpilot c330 onto your hard drive.
  2. Connect your Streetpilot c330 to a free USB port on your PC with the correct PC interface cable.
  3. Unzip the files in the archive by running the downloaded executable file.
  4. Follow the instructions provided by the launched update application on your computer.
Get the update here:
http://www8.garmin.com/software/StreetPilotc330_610.exe
Mar 19, 2009 | Garmin StreetPilot C330 GPS Receiver
Upgrade maps
You can get the updated maps for 2009 from this website, but you will have to pay for them: http://www.gpsnow.com/Garmin_StreetPilot_c330_Maps.htm
Feb 09, 2009 | Garmin StreetPilot C330 GPS Receiver
My StreetPilot c330 unit says ?Can?t Unlock Maps? when I power it on. What is the problem?
My Streetpilot c330 and it says? can't unlock maps? How can i fix this problem.
Oct 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c330, won't re& change maps.
I'm not 100% sure but we were told that there isnt' enough memory to hold all the maps in the c330 because the new maps are larger than the memory in the c330. Does it have an area to choose where you can take out Canada? If so then it has enough memory to load the maps minus Canada. Hope it helps you a bit.
Oct 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Update 2009 for Street Pilot c330
2009 upgrade data is too large for garmin 330 must have sd card
Jun 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
2,222 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
