Question about Smeg FAB28
SMEG FAB28 I'm getting alot of condensation build up inside the fridge, underneath the freezer compartment.
  • Anonymous Mar 06, 2008
    oh yes! The door does not seal, so the fridge constantly drips water.
    It is the worst product I have ever bought. It has been exchanged twice and it is still useless. Just waiting for it break completely then I can take it to the TIP!
    Canot be fixed
Check the seal is tight all around the door - clean it to within an inch of it's life.
Then make sure the drain hole (inside at the bottom of the fridge) isn't blocked (a long handled screwdriver with kitchen roll wrapped around it will suffice). You can tell the drain hole is blocked as it's characterised by the door being difficult to open in quick succession (plus - you can see it's blocked).
Next, defrost the fridge completely: Power off, open door on freezer compartment & fridge and mop up the damp. When totally dry, turn back on (without food - let it cool properly before putting food back).
I had the condensation problem and it's now sorted. Not sure which cause was responsible, but the 'solution' is worth a try.
David W.
Posted on May 22, 2008
This is a known problem with these fridges. The only fox is to replace the fridge.
Posted on Dec 27, 2007
SOURCE:
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Fridge not getting cold
There are 3 likely possibilties, either the compressor is heating up and tripping or if the compressor is working there is a leakage of gas, the third is there is slight moisture or jamming in coil, filter or pipes which is causing uneven cooling. Cheerio
Nov 10, 2013 | Smeg FAB28
Smeg CR330SE fridge/freezer hi there fridge freezer has stopped cooling in both compartments. light still comes on in the fridge and the compresser at the back is very hot.... any ideas???
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Smeg CR330SE 1 Bottom Freezer Refrigerator
Fridge stopped working, light still on when door open. Bought and fitted a replacement thermostat. Fridge made noise like it was working for about thirty seconds and then stopped. Is not getting cold but...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | Smeg FAB28
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Smeg Fab40 fan stopped working - there is a build up of ice at bottom right freezer.
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
Mar 31, 2010 | Smeg FAB40PS Top Freezer Refrigerator
Light bulb in FAB28 Fridge
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side.
Mar 06, 2008 | Smeg FAB28
Smeg 50's stle fridge
we had so much frost that the fan couldnt turn to keep freezer cold. we defrosted it and it ran fine. someone left the door not shut all the way and tahats how it got wet and then refroze.
Dec 22, 2007 | Smeg FAB28
Smeg FAB28 Logo
1,246 people viewed this question
Top Smeg Refrigerators Experts
Mike
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
