Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Convergence would like to know the part # for convergence board replacement
  • 2,920 Answers
You would need to pull your board and get the number from it to get the right one
Posted on Jan 15, 2009
Convergence problem
Usually what happens is that the convergence IC goes bad or the fuse going to the convergence ic goes bad. Pico fuses they are called sometimes open up. You may want to open it up and pull the board out and check the solder connections on the convergence IC. Sometimes these get fractured or cold soldered and aren't making connection to the PC board.
Let me know if you feel comfortable with pulling TV chassis out or pulling the board that has the convergence IC on it out. Then you can resolder convergence IC OR replace it.First thing i would do is check to make sure there is between 22vdc and 25vdc on the fuse or the convergence IC. Let me know if this helps out any.... Sincerely HDTV GURU JAY
Mar 17, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
RCA D52W23 Color Alignment. Blue,Red,and
Its problem of convergence board and need to be replaced. You can buy this board at Part Store.
Please replace the board if you have basic electronics knowledge or get help of tech person.
Sep 19, 2008 | Televison & Video
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
I have the akia projector tv and the numbers and letters are doubled. Also the color isn't right . Is it the auto focus ? . Please help I don't know how to fix this ...
The tv problem is call convergence problems,it dead.Tv have convergence colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must replaced on the tv convergence board to solved the tv picture convergence problems.Try website like might still can buy a whole refurbish convergence board for the replacement.The Akai and Samsung DLP tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 06, 2011 | Akai PT5598HD 55" Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem w/55h70. red is ok but can't fix blue. Is there a component or board that is easily replaced?
Yes,U have some basic machanicals skills?The Toshiba Tv convergence board,it call a Hyper board.Try website to buy a refurbish board.This board no longer produced by Toshiba,if can't find it.The Convergence 2 STK ICS,and some or all it resistors,must replaced manually.Must have tools,and knowing how to do basic soldering,to do this.
Apr 06, 2010 | Toshiba 55H70 55" Rear Projection...
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
Replaced convergence board but still out of convergence. what's next?
1- Did you try converging it by way of your menu?
2- Sometimes they have fuse-able resistors on the deflection board that go open when the IC's take a dive.
3- If this doesn't help then I will need your model number and make and you will need to get your DVM ready for trouble shooting.
4- I haven't had to replace a convergence board complete in 20 years, I don't know why your wanted to do that. Replace the IC's and possible resistors and your back in business.
5- Let me know!
Jul 11, 2009 | Samsung HCM5525W 55" Rear Projection...
Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Oct 21, 2008 | Hitachi 43F300 43" Rear Projection...
HC-P4752W - IC Replacement vs Convergence Module.
The colors weren't lining up correctly on my HC-P4752W which is only about 30 months old. I did a little bit of research and got ahold of the people at They recommended replacing the IC's as well as the IC resistors. I purchased the replacement parts from their site and made the repairs myself. I should mention that I didn't have any previous soldering experience. The repair was easy and a complete success. You may find replacement parts elsewhere for slightly cheaper but what you won't find is the prompt and detailed customer service that they provide. They gave me there # and said to call if I had any questions before or during repair. I took advantage of their services and got answers every time I called.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
