Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I have been heating for about 5 days straight. Day six it has started to shut off every 15 - 20 min. I have been using diesel fuel and havent been very carful about cleaning snow out of funnel. Do you think water is the problem. I added water treatment to the fuel just a minute ago. What do you think.
  • 92 Answers
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Posted on Jan 24, 2009
I have a 40,000 btu reddy heater multi fuel heater. the fan starts but there is no flame and it will shut down after only a few seconds
That's the safety; it's supposed to do that to keep you from getting blown up!
Did you follow these instructions?:
http://www.ehow.com/how_10008271_reddy-heater-instructions.html
Does the power light come on?
Does the igniter heat up for 5 seconds?
Jan 24, 2013 | Reddy Heating & Cooling
Hi i have a ready heater 170T i cleaned it last year to help out our main heater in our barn for when its get way to cold for our main heater to keep up so i turn this on when i am back there for the day...
Based on your description of the problem ............The part where you say "wont relight till it cools down" is a sign that the motor may be getting hot, the internal sensor in the motor is shutting things down for safety reasons. To find out run the heater til it shuts down then remove the cover. Feel the motor. It should be room temp or slightly warm. If hot- replace the motor with 102001-30.
Other possibilities would be a defective thermostat or temperature sensor. Eliminate these possibilities first.
Sep 07, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Have a 115000 btu forced air kerosene heater.. used maybe 12 times over 3-4 years. when turned on motor is binding somehow. i maqnually turned blade and does not spin easilly. whats causing this?
Unfortunately it is the lack of use that has hurt this unit. Try using PB Blaster on the bearings and working the fan by hand until it loosens up. It will loosen up eventually, when it does give those bearings lubercation with a light oil. From running and shutting down and not using it for a while I would think that things got a little rusted up inside, this happens due to condensation forming on the warmed parts then it rusts. You can check the fuel pump but they usually are not an issue with the heaters.
Dec 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Keep getting E1 error code, where is the fuel pump located? where is the fuel filter located on my dyna glo deluxe multi feul 170000 btu heater
The fuel pump is directly behind the fan motor as the fan motor runs both. The fuel filter is under the electrical control panel on the side of the heater usually has four to six 5/16 head sheet metal screws that hold it on. Remove the screws and then the cover comes off and this is where you will find the fuel filter.
Dec 21, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Hello my Raypak Versa Heater sounds like its working just fine. I have it on high and it is definetely letting off heat, but my pool temp has only climbed 1/2 a degree in 4-5 hrs. I have a 25ft x 8ft...
When checking functionallity of this heater heres what we need to look at.
Your pool is 6660 gallons with a 55,000 btu pool heater.
Right off the bat I can tell you that this heater is meant for a spa or small pool only.
Depending on where you are located this heater will not even keep up with heating this water in cold temperatures. You should have a 100,000-150,000btu heater installed for this pool.
Since this is what is installed, here it goes.
Make sure there is adequate flow to the heater. All heaters have a recommended flow rate which is more more productive than one that is too fast or too slow. Ideal for this heater is 55-65 gallons per minute, so make sure that the pump is not clogged and flowing freely.
Also, if this is an old heater and hasnt been serviced in quite a while, then the heat exchanger is probably overdue for a cleaning. When the heat exchanger gets dirty, all that heat produced by the burners just gets vented instead of heating the water. a yearly service is highly recommended on these low efficiency heaters.
By the way, you have a 55,000 btu heater that was 81% efficient the day it was installed.
This means that the actually heating btu's is already down to 50000.
the efficiency of these units will go down 2% a year if serviced, and about 3-5% a year if not serviced.
Long story short, the heater is undersized, and probably also needs to be cleaned.
Nov 15, 2010 | Raypak Versa 55 Electronic Ignition...
Good day, I just moved into my new home on August
It sounds to me that the motors on the units in question, may need a few drops of oil on the bearings. I have seen motors in these heaters and most do have a place to oil them, they wouldn't have sealed bearings as the newer motors.Check the blower wheels also for dirt build up on the blades, as this will cause them to be out of balance and cause some noise also.
Sincerely, shastalaker7
Oct 28, 2009 | Goodman GMS90703BXA Heater
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Dec 03, 2008 | All-Pro Forced Air Kerosene Space Heater...
Heating & Cooling Logo
350 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
