Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Pro 155 kerosi ne heater
Pls help have pro 155 heater for my garage when i start he only work for few mins and stop.
  • scottygoblue Jan 26, 2009
    I have the same problem with mine, I have replaced the phot eye, and put new fuel into the heater. My heater has also only been used one time, for about 3 hours.
  • 92 Answers
Check your fuel and air lines for leaks, typically it's the CAD flame sensor but if you have already replaced it try checking the high heat limit switch. It looks like a thick watch battery just behind the combustion chamber, take it off and hold a lighter under it. If it's working properly you should hear a faint click when it shuts off, no click then it's bad.
Posted on Feb 03, 2009
I have a All Pro 150,000 Torpedo heater, it will turn on and then after a few min. the unit will turn off, a poff of white smoke will come out and then turn off
Take the cover off and see if the heater runs ok, if it does then you have an air problem. Check the air pressure. Check for any cracked air lines, or any other plastic parts associated with air, don't forget to check the plastic piece that the nozzle screws in to.
Dec 12, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
Tip
All pro 155 kerosine heater
i have pro 155 kerosine hewater when i plug it in he atart whork for 2 mins and stop pls help
on Jan 15, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene garage heater (Desco) fan starts, burst of kerosene, and the heating element is red. Within a few seconds, heater stops abruptly. Email address: p.s.stohr@sbcglobal.net Thanks for your help.
Remove the top from the heater and clean the flame sensor. It should be the photo eye type. Remove it from it hold and clean inside with soft cloth or cotton swab with alcohol. If this doesn't help, let me know what you find. nitensheaterservice@earthlink.net
Jan 11, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
110,000 btu all-pro heater 2years old ,runs 2 mins and cut off ,cleaned filter,didnt help
take off rear plastic filter end cover. check very close for hair line cracks and make sure that plastic rib that seats around cork portion of gasket is not warped
Feb 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Motor tries to start but sounds like it is freezing up.
It sounds like the motor may be going out. I suggest you contact Master Parts at 800-446-1446 or you can find them online at www.masterparts.net they should be able to help you find the part you need. I hope this helps!
Jan 10, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
130 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
