Question about HP Photosmart C3180 All-In-One InkJet Printer
No button response from printer
I can successfully print from my laptop. I can't scan, copy or turn off the printer. I turn it off by unplugging it from the wall. The buttons do not respond. The display stays stuck on options to scan copy(BW) and Copy(color). Interestingly, I went to Best Buy where I bought it and they had no problem. They were able to copy, print an alignment page and turn the printer off. This printer does have wireless capabilities. Could the printer be interfered with by signals? I have no other printers in the house.
    Problem Solver:
  • 8 Answers
I could be off in my assumption, but I'm going to assume you are running Vista?
I heard of someone else encountering this issue with Vista and it must be a know bug. Check out this doc on HP's Customer Care site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01579338&cc=us&lc=en&dlc=en&product=1146331
It looks like there is a fix available for download.
Cheers,
_K
Posted on Jan 16, 2009
When I print colored squars show up in the background
Update your printer firmware http://bit.ly/JqfYcG
After successfully updating your printer, run the Deep Clean Printhead function on your printer.Press the Setup button > Maintenance > Deep Clean Printhead.
If you're still having problem, please scan and email us a test page (Setup button > Maintenance > Print Test Page) to LxkListens@Lexmark.com.
Jun 04, 2012 | Lexmark Intuition S505 Wireless All-in-One...
I have a mac book and have always successfully been able to print wireless. The scanner however would never work. Yesterday I needed to scan a document so i plugged the printer into my mac and scanned...
Check the settings on the printer to see if you have to switch from scanning to printing, also if you have the original setup disk for the printer just run it again and that will solve the problem.
Mar 19, 2011 | Computers & Internet
The printer prints an allignment sheet every time its turned on.
Bypassing the print cartridge alignment It is possible to bypass the alignment page and use the information from the last successful alignment. Print quality may not be as good, but the product will operate. The table below describes how to bypass the cartridge alignment. Try either one of these: Press and hold the Enter button, and then press Setup or Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | HP PSC 1350 All-In-One Thermal Printer
My problem is a weird one. My family has had a Photosmart 3310 All-In-One printer for a while now (I'd say about 3-4 years), and it's worked fine until recently. Now, the light is on around the on button,...
Hi, I suggest you do a full system reset on the printer and see if that fixes anything. Please do the following. Come back and check with me if it doesn't work.
Performing a semi-full reset of the All-in-One
  1. Use the Power button to turn on the product.
  2. Unplug the power cord from the back of the product.
  3. Press and hold the # button and the 6 button.
  4. While holding the buttons down, plug the power cord into the back of the product.
  5. Continue to hold the buttons down until the control panel display goes blank.
  6. Release the buttons, and then use the Power button to turn on the product. The reset information appears on the control panel display.
Aug 12, 2010 | HP Photosmart 3310 Printer
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Just changed both ink cartridges. Test prints fine. Tried to copy a doc, prints wall to wall black ink. What's up?
hi first of all try to scan something from your computer if scan is fine then open solution center and then go to solution center and click on settings after that click on printer tool box click clean print heads/cartridges after cleaning align then now try to copy
if still you have a problem then Perform a reset of the HP All-in-One
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. Turn on the HP All-in-One by pressing the On button.
Aug 05, 2009 | HP PhotoSmart C4280 Laser Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blinking panal lights/no responseno communication w/computer.Help
hi you can try these steps:
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
  • If the error message displays again, proceed to the next solution.
2)
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
  4. Disconnect the power cord from the product.
  5. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
  6. Try making a color copy by pressing the Start Copy Color button on the product control panel.
  7. the # and 6 will reset the whole printer as it is factory, I hope it will work fine!!Best of luck!!
Jul 03, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark x2600m printer not queueing
The best Solution for this would be goto Start click on Run type in Services.MSC and click ok now on that window u will see an option saying print Spooler just restart that by right clicking on it......
now go to control panel and go to the Printers Folder......
Right click on the Printer Icon and click on Properties......
Now click on Advanced and then go to Print Processor.......
It will be by default on Lexmark LEMF change it to Lexmark NTEMF 1.008......
Click on Apply click ok......
Restart your Computer and try to use it it should work......
Good Luck...........
Jan 09, 2009 | Lexmark X2500 All-In-One Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
