Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Printing secure documents
I just wondered when you send a secured print job to a printer how long will it stay on the printer before it deletes or does it stay there until the person actually deletes it?
    New Friend:
You have to specify how long you want the job to be kept
Posted on Aug 01, 2013
  • Konica Minolta Master
  • 2,794 Answers
Secured print jobs only stay in the printer until they are printed. If you want to keep a document in the copier, you have to use the bulletin board system under the scanner section of the copier.
Posted on Jan 15, 2009
I was printing a job and had reworked the document and wanted to print it again, but, all of a sudden, the printer does not print or copy anything. All the cables are securely fastened. I have plenty of...
unfortunately, you have to delete the print queue, then delete the printer (including copies of it if there's any). unplug / reconnect usb cable
Apr 04, 2008 | SATO M-8450 Printer
I have a manul I'm wanting to print, but now I don't want to print it. How do I stop it? And also it is printing little boxes (Not the words) What do I do about that?
Runaway print jobs are always a pain! First, power off your printer to stop it from wasting paper. If the power button doesn't work, pull its plug. That will stop the printing for now but your print job will probably restart when the power is resumed.
Whether you are using a PC or Mac, documents that you send to the printer are managed by a printer management service which is responsible for printing documents in the correct order and handling any printer problems that occur. When the printer is turned off, any documents you print will be saved (queued) for printing when the printer starts again. To fix your runaway printing problem you simply need to delete the copy of your large document that is still queued for printing.
On Windows you will see a small icon on the toolbar at the bottom right of your screen that looks like a printer. When you click on the icon you should see a window appear which has the name of your printer in the title bar (e.g. HP Deskjet) and a list of any documents waiting to be printed. To delete a print job, simply right-click on the document name in the list and select "Cancel". When asked "are you sure you want to cancel the document" click on YES and the document will be deleted from your printer queue. Repeat this for all documents in the list until it is empty, then you can restart your printer.
The process on a Mac is similar and even easier since you will see a bouncing printer icon with an exclamation point on it on your toolbar. Click on that icon to see the print queue, click on the document you want to delete and press the DELETE key to remove it.
Jul 30, 2013 | HP DeskJet 6540 InkJet Printer
When I cancel a printing job, it stays waiting to be printed the next time I want to print. How do I delete it completely. Is there a list of printing jobs that I could edit?
If you are on a Windows computer, there will be a printer icon in the bottom right corner where the time is. Click on it twice. Or right click and Active. Then click printer and delete all documents.
Mar 04, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Will not print
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
332
Aug 28, 2008 | HP Officejet 5610 All-In-One InkJet...
I, could you give me your e-mail adress so i can send you the user manuel for security....
Make sure ti that you have a hard disk in your copier ???
Thank you!
Mar 27, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Secured print
Most copiers will only hold a job in secure print for so long. It may have timed out and deleted the job. You should be able to change how long it holds jobs from the configuration menus. Don't set it to never delete because the hard drive will fill up.
Feb 21, 2008 | Canon IMAGERUNNER 6570 Copier
Paper wont load
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
Lexmerk Z600 Series Printer won't delete document after printing
check your allowed programs in your security suite to see if your print programs are allowed
Nov 14, 2007 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
299 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
