Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Power on I turn on my vaio laptop, dvd-rom runs nothing else. no activity what so ever. then i have to remove battery to shut off. what happened to it?
  • 3 more comments
  • Trish Sherwood Jan 15, 2009
    there is nothing on the screen. but there is also no sound indicating that the computer is running. only the dvd-rom with recovery disk inserted but no processor sounds
    where would i find the memory strip?
    im not sure. its my friends. all i know is it is a sony viao purchased brand new about 3 years ago. It was a pretty nice one.
    thank you so much. i will let u know how it goes
  • micromaster
    micromaster May 11, 2010
    is there anything appear 0n the screen 0r it was empty n0 0utput int0 the lapt0p lcd?
    Brigadier General:
  • 3,614 Answers
If u can easily access the |apt0p mem0ry strip, try t0 rem0ve the mem0ry 0n the s|0t and wipe and c|ean the br0nze meta| and put it back again 0n the sl0t pr0per|y.
|et me kn0w
Posted on Jan 15, 2009
  • 2 more comments
  • micromaster
    micromaster Jan 15, 2009
    it |00ks |ike this
    may i kn0w exact|y the m0de| 0f the |apt0p?
  • micromaster
    There are 2 locations for RAM. If your laptop only has one RAM
    module,
    it will be accessed under the cover on the bottom of the laptop (Steps
    1 to 5). The 2nd RAM socket is accessed from under the keyboard (steps
    6 onwards).
    1. Shutdown the computer
    2. Turn it over and remove the screw labeled A circled (sorry about the blurry photo)
    and remove the cover
    3. Remove the cover
    4. Remove the original RAM (push the metal clips outwards) and replace
    it with the new RAM
    5. Replace the cover and screw A.
    2nd RAM Socket
    6. Remove the 2 screws labeled B in the first photo in these
    instructions
    7. Along the top edge of the keyboard, there are 3 very small latches
    which keep the keyboard in place (they might not be exactly where the circles
    are in the following photo - but they'll be close). While very gently
    levering one top corner of the keyboard upwards with a small screwdriver, using
    another very small screwdriver, push the spring-loaded latched upwards (towards
    the top edge of the laptop). Start with the latch closest to the corner
    you are gently levering up, and work away to the furthest latch until you should
    be able to lift the keyboard up and fold it forward (as shown in the next
    photo).
    8. Remove the 2 screws from the recesses circled and remove the thin
    metal cover.
    9. Rem0ve and Insert your RAM module.
    10. Replace the thin metal cover and 2 securing screws
    11. Fold the keyboard back, locate the lugs along the bottom edge, then
    press the top edge down to clip it in place
    12. Turn the laptop over and replace the 2 screws removed in Step 6
    All Done
    if y0ur n0t sure 0n h0w t0 d0 it. its better t0 call a pr0fessi0na| t0 d0 it
  • micromaster
    u can |00k the m0de| in here
    the part which has circ|e and X u can find the m0de| #
  • micromaster
    0ki d0c..
    g00d |uck!!!
My Toshiba Satellite 1805-S204 turns off when i'm trying to open DVD-ROM bay. Sometimes i can open it but than notebook turns off when i'm closing DVD-ROM bay. I want to disassemble 1805-S204 to find out...
I suspect, if you haven't got it working on the AC adaptor when this happens, that maybe the battery is low power. If it does it when the AC adaptor is being used then I think you are right, the DVD ROM is faulty.
Remove the battery and AC adaptor.
Remove the Memory cover.
There is a singel screw that holds the DVD drive bay in. Remove the screw and pull the drive out.
Replace the drive with and IDENTICAL model and that should be that.
Hope this helps.
Nov 06, 2010 | Toshiba Satellite 1805-S204 Notebook
My laptop doesn't turn on
Usually indicates a problem with the motherboard.
Try removing the battery, reseatting the memory.
If that doesnt' work remove the dvd-rom and also the hard drive.
We're just trying to get a display at this point ;)
Let me know what happens.
Apr 03, 2010 | Sony VAIO VGN-FS830/W Notebook
My Vaio will not come out of standby mode without having to be shut all the way down and rebooted, I have adjusted the power setings to ensure that nothing is preventing it from going into standby mode....
If the 10-sec thing doesn't work, then try this:
- unplug the mains power.
- remove the battery.
- leave for a minute.
- fit the battery back.
- plug in the mains lead.
- try switching the laptop on.
If it works, then run Windows Update to download the latest fixes to try & stop this happening again.
If it does happen again, try going to the website of the laptop's manufacturer & check on their Support pages to see if they have a fix for your problem.
Jan 16, 2010 | Sony VAIO VGN-FE550G Notebook
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Software not booting up
any light on the laptop try remove battery and power cable and hold the power button for 10 sec and then connect the battery and power cable and turn on the laptop
Mar 13, 2009 | Sony VAIO VGN-FW235J Notebook
Gateway 7330GZ wont boot
for me this is the try and test situation,
try to remove ram -- look what happen. or try to turn on the laptop with the xp cd in the drive rom, there a similar case and the problem solved after i take out the keyboard and put it on again.
Jan 18, 2009 | Gateway 7330GZ Notebook
Toshiba Satellite iss getting power but won't start up
Try pressing F8 to start it in safe mode. If you get into the operating system, Go to System Restore under the STart-Programs-Accesories-System tools-System Restore. Pick a date before the laptop started this problem, and the wizard will guide you the rest of the way.
Nov 25, 2008 | Toshiba Satellite A105 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
239 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
