Question about Zenith B32A24Z 32" TV
Video problem tv has no video,but sometimes shows a picture than pic goes out. tried video processor ic2200 same problem,checked abl line and voltage. check v&h pulses, checked data and clock lines.
  • 398 Answers
Check the solder joints on the vertical output IC. I am not sure if that model has the PIP module, but if it does then resolder those connectors, too.
Posted on Jun 29, 2007
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
How do I restore missing video?
Video processor IC [Chroma IC] fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 14, 2015 | Televison & Video
I have BPL 21 Studioline 1000W, problem is suddenly the picture is becoming a thin Horizontal line at center, sound is perfect, when i beat with hand behind the TV picture is back to normal state, picture...
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
The fault is the FAILURE OF THE SOLDER IN THE VERTICAL IC OF THE TV.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Jul 25, 2011 | Televison & Video
No picture at all, black screen, audio works , cant work menu cant see it
sounds like video problem take to tv shop they will address your problem okay good luck
May 02, 2009 | Televison & Video
I took the scan disk out of the voyager to copy to my pc
To be able to do this you have to plug it back in then go to My computer. It should come up under removable storage. After that copy the files and paste them on your computer. Once you double click the picture you can see them.
Dec 21, 2008 | LG VOYAGER VX10000 Cellular Phone
Preview mode not working and lines on the screen
canon ixus 500.
when i switch mode to playback/preview it doesnt work so i cant view pics that are taken or can i upload them to my pc.
Jun 28, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Av black and white
please don't take this as me doubting your intelligence, but are you sure your wires are good? sometimes they can become worn out inside of the protective rubber, and partially fail.
Also, how old is the TV? I just got one (for free so i can't complain) from a friend that will start in color on av and then turn to black and white because something inside of it went bad..
May 09, 2008 | Spectra Logic Hello Kitty 13" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Zenith B32A24Z 32" TV Logo
27 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
