Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
Changed both thermal fuses still nothing. the light inside works when pressing the switch on and off. when i pull the start knob the damp light comes on. i'm at a loss
  • Anonymous Jan 16, 2009
    Same problem here. Someone mentioned we should replace the timer?
  • 979 Answers
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Posted on Jan 21, 2009
  • Bill Dickerson
    Bill Dickerson Jan 24, 2009
    Have you had it looked at yet?
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Can not locate the thermal fuse on my dryer, maytag atlantis mde7400ayw
Hi khartley317
You will have to remove the back of your dryer andiIt will be located on the air tube.
I will send you to this webpage to see where it is located and you can purchase your part there Please take time to rate me
http://www.partselect.com/ModelFrames.aspx?ModelID=149441&ModelNum=mde7400ayw&mfgModelNum=&ManufactureID=1&Selected=51031&Position=4&mfg=Maytag&Type=Appliance&Mark=4
Jul 02, 2011 | Dryers
Mde7400ayw wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
No power to machine.
HI, check the following to address this issue.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 12, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need to know how to check if the fuse is bad in my Maytag MDE7400AYW dryer
Check the breaker first in your breaker panel. I am sure you have and also the wiring in the back. The thermal fuse or hi limit fuse is fairly easy to check. It is probably located under the top of the dryer. You can ohm it out or if you don't have a tester, simply bypass the fuse (probably short barrel shape) and then try to turn it on. If it does, then the fuse is bad.
Dec 24, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Nov 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
315 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
