Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT-47WX49 convergence amplifiers
I started out with the red picture out of alignment, I bought new convergence chips , replaced them but still have the same blurry picture. neither the remote or the guns will re-align them perfectly. this pt-47wx49 is only used for my sons game play in the basment but would still like it to be used, any info. on these problems would be great,, thanks
  • jonnylaw Jan 15, 2009
    thank you , would there be any one that could get me a manual download of the main board or where i can buy new resistors from , thanks again
  • 4,234 Answers
Often when the convergence ICs there are small valued resistors close by that open up as well. These resistors are used as current limiting resistors and when the ICs fail, they short causing excessive current draw. I don't have the manual close by, so this is from memory, but look around the ICs. You should see some low valued resistors tied directly to the pins of the ICs. Check those for proper value. I suspect 2 will be open (infinity reading) rather than their expected values. This means that there is effectively no power going to the ICs.
Let me know what you find.
Dan
Posted on Jan 15, 2009
    Champion:
  • 240 Answers
Check R7059 and R7050
check for 2.2 ohm.
if not 2.2ohm replace them.
values are 2.2ohm at 2 watts
also look for bad soldier around all serounding resintors.
I have a Panasonic PT-47WX53, this morning when i went to turn the TV on the picture was not align. The red and blue look aligned but not the green, i opened the back and when I coved the green light the...
This kind of problem occurs due to failure of convergence output chips located on main circuit board of tv and replacement of convergence output chips will hopefully solve your tv problem.
Soldering work is involve to replace these two chips so have local tv repairman for that job if you are not familiar doing so.
Thanks.
Jun 29, 2011 | Panasonic PT-47WX53 47" Rear Projection...
The picture is producing a double image which appears to be in red only with a slight bending of the images on some parts of the screen.
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Everything has red highlights. but adjusting with the remote does not change things to correct the problem?
Go into the menu with your remote a click on picture next scroll down to convergence and click on it. Follow the on screen instructions on how align or converge the diffrent color lines togeather. It will usually have a white cross on the the screen. This should solve your problems if not have a tech replace the 2 convergence chips in the back of you set
Aug 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Vertical lines dont align and green tint
First do a convergence on your set go to menu select picture then scroll down to convergence then press select again. Next follow the on screen instructions for static convergence. If this doesnt solve the problem check all the capacitors in the convergence section of your TV. If problems persist replace both convergence chips. Please have tech do this for you.
What is a convergence amplifier
The convergence amplifier is a three channel Integrated circuit which controls the convergence alignment of the three picture tubes in a rear projection TV. Your convergence amps are STK392-110 there are two of them also check the six 2.2 ohm 2watt resistors
Aug 06, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
