Question about Reddy Heater-170,000 BTU Kerosene Deluxe
R155A Reddy Heater Help!
I have a R155A Reddy Heater that will not ignite the fuel unless I unplug and plug in the unit several times (3-4). Once this procedure is done the unit will fire & run perfect I have replaced all fuel & vacuum lines, air & fuel filters, nozzle, H.S.I., photo cell, rotor (am I missing anything?). The pressure is set to 5psi, doesn't smell, checked for vacuum leaks ........... Maybe you can help before I go out and buy a new heater
Thanks
hojo
  • 232 Answers
This is going to be a tough one. You have been thorough, done it right, and it damn sure ought to fire off every time!
There is something that is causing you a problem and don't think that because you put in new parts that you didn't get a bad part. It happens. Not often, but it does happen. I have rec'd nozzles from the factory that had the orifice installed sideways, so, I know it happens.
If the ignitor glows- (it only stays on for 5 seconds, then quits)
If the fuel fogs (not sprays)
If the fuel hits the glowing ignitor
Then it should fire off-- every time.
Now, if the photocell doesn't like what it sees, then the photocell will shut the heater down within 5 seconds, but it at least should have ignited. Right? Unless the photocell or the board are bad. Maybe.
Lift the top, and watch. What's happening. Are you having a fuel problem or an electronics problem? For instance- is the ignitor glowing every time at start up or only sometimes.
Let me know what you find.
Posted on Jan 15, 2009
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Feb 23, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater R155A
Congratulations. Was it the original fan, or had it been changed out?
Jan 24, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
179 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
