Question about Intel Motherboard
After installing new motherboard and processor my pc doesn't booting. no beeping, no display, no sound but it seem it works, because the cpu fan run well.
    President:
  • 2,351 Answers
Hi achmadjanupe, please include in this post the manufacture & model number of your new motherboard. (That will help a lot).
You must first clear the cmos by moving the cmos jumper to clear & wait at least 10 seconds, than move the jumper back to normal. (See your manual for this).
After installing a new motherboard & CPU it is not uncommon for windows not to boot & you will not hear a POST beep. Try removing your system memory & reseating it. If you have an AGP or PCI-Express video card, do the same. If you are using the same hard disk drive from the older MB & CPU you'll have to do a fresh install of windows, (Including a format of your hdd). Its a very bad idea to install newer drivers over old drivers for a newer board.
The only exception to this would be if the new motherboard is exactly the same as the old motherboard. Once you gain display, go directly into the bios & make sure your hdd is listed in the boot order.
If your hard disk drive is large enough. You can add a new partition within the free space of your drive & install your new windows onto that partition. When you boot to your windows CD follow the instructions on screen to create a new partition within the free space of your hdd. By doing this you'll be able to save all the old data within your old windows drive. You'll be able to copy & past your old data over to your new installation. Once all your data has been copied to your new windows you can delete the old windows & old partition by booting again with the windows CD. Windows can delete the old partition.
There is far too much information, drivers & registry information already in windows. If you try to run your old windows with the new board it will go crazy & you’ll have nothing but trouble.
Good luck achmadjanupe!
This will take some time to complete.
I'm sure you may have more questions, post them here.
Mike
Posted on Jan 15, 2009
My motherboard have power but no display on screen
Please follow the following :
* Make sure that you have connected the Monitor cable firmly.
* Make sure that CPU fan is spinning else check & make it run (your pc won't boot if you missed your fan).
* Check for any unusual beep sounds after you switch on.
* Remove your RAM, Power cables, other Add on cards. Clean/wipe them properly and reinsert them correctly.
* If your PC installed Graphic Card, remove it and run your PC again using your onboard vga port.
* Replace your Power Supply Unit with another good conditioned one.
If the problem persist check your processor.
Oct 13, 2012 | ASUS P5KPL-AM/PS Motherboard
I am using a intel Dh61ww board with intel i3 2100 processor. When i switch on the pc the cpu fan rotates and halts.no display. pls help me.
The steps I would take would be : 1 make sure you have a power supply with the proper power connections and at least 500 Watts 2 remove and reset the power connections, try to boot 3 disconnect all hard drives and cd/dvd's, try to boot 4 remove all ram/memory sticks, try to boot and listen for the beep or beeps if it doesn't beep and still shuts off, you have a bad motherboard and/or cpu if it does beep, you need to try different ram
Aug 23, 2011 | Intel Motherboard
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
CPU Heatsink is cool but fan runs fine no display
No beep or sound means Motherboard Defective, aside from Processors is OK, Memory is OK, and the rest!
Buy a new one not as the same Motherboard you use. ASROCK Motherboard are have a a problem when high temperature occur.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 29, 2009 | Asrock P4I45GV R5 Motherboard
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
No display when i turn on pc
You mentioned there were no beeps. Do you not even get the single beep (Post)? Did this issue only start after removing and reseating the CPU/Ram? If so, check they are seated properly.
May 25, 2008 | Dell (2336V) Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Intel Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
