Question about RCA 27F530T 27" TV
TV contantly searching
My tv all of sudden started doing channel searches by itself. During this, it started shutting off and on. Then, the tv may work for a couple hours before it started the process again of searching for channels, then shutting off and on. Nothing liquid was spilled near it and I am hopefully assuming, I don't have a poltergeist! I finally decided I would try and delete the other channels besides 4 since that is the only one I need for the cable. As I was doing this using the menu function on the tv (since I long ago misplaced the tv remote, I use the cable remote) I accidently chose something I think called an FPA4 lock. I guess I chose yes and my tv went off. I have no idea how to unlock it. Any ideas about any of the above problems? The tv is only about a year and a half old.
  • socialworker Feb 22, 2008
    the tv will not come backon. i can not find any reset button
Where is the eeprom located ?
Posted on May 29, 2008
Did you find a way , if not, change the Eeprom you will restart the original set up...
Posted on Jan 17, 2008
    Problem Solver:
  • 6 Answers
The keyboard has bad tact switches or the infrared detector has some issues. you can unsolder the keybard switches one at a time, or you can replace the whole keyboard with some of these models
Posted on Aug 09, 2007
My tv, smart tv keeps shutting off during the setup procedures, won't get past the wireless connection search. Searches for wireless connection but shuts off before one is found.
The TV is shutting down because it is getting no signal from the selected input, so it turns itself off, it is not a problem it is deigned that way,.
Nov 11, 2016 | Televison & Video
Tv suddenly shows no audio and no video for digital channles only yet all digital channles are detected durring the channel search
Sounds like you have a bad signal from the antenna or the cable. Unlike analog TV if the signal level drops below a certain level you loose the picture and sound completely. The fact that digital channels are detected during channel search does not mean they have a good signal. Try moving the antenna about.
Nov 29, 2009 | Olevia 237T 37 in. LCD TV
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Can`t receive all t.v. channels
get a menu of the tv and enter into a channel searching select auto and press search, automatically your tv will start searching. each signal found will be stored on each one channel.
later just store those channels into the memory of the tv.
Apr 29, 2009 | Bush 2871NTX 28" TV
Sudden channel changing,flipping off and on and channel searching
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 21, 2017 | RCA F36649 36" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Channel constantly searching
#1 resolder cpu oscillator crystal #2 replace eeprom ic. #3 go to service menu set parameter "07" to "00" try one of these steps one at a time.
Jun 16, 2007 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
55 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
