Question about Pinnacle Dazzle DVD Recorder
My system does not load coreldraw 12, it will appear and diappear in a seconds
    Problem Solver:
  • 5 Answers
Uninstall application,restart system then locate coreldraw installed folder in programfiles directory and delete remaining files that are not deleted during uninstallation.now install again,it should work as it is.
Posted on Jan 17, 2009
After i uninstalled coreldraw 12 and installed coreldraw X5 trail, everything when wrong so i uninstalled coreldraw X5 but now i can't reinstall coreldraw any version and to other applications like...
Hi ebiau
Probably , if you have deleted coreldraw 12 via Control Panel , some files remained in the registry , corrupting current installation attempts .
Use the restore system application to set your computer back to an earlier date when everything was running smooth .
Next time you need to delete a program , use a proper tool like free RevoUninstaller from :
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Best regards ,
fanaudi .
May 13, 2011 | Computers & Internet
I can't open corel draw file ver:12, please help me.
Probably the file is corrupted. Try to use program method for resolving trouble http://www.coreldraw.fixtoolbox.com - it must help you
Feb 17, 2011 | Corel AE CorelDRAW Graphics Suite 12 for...
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
Coreldraw 12 does not launch even on new installation of xp and coreldraw 12
Are you receiving any errors?
Is this the shortcut on your desktop?
I would try navigating to the actual coreldraw.exe file
windows logo + r
type
coreldraw.exe
If it's anything like microsoft word you can use this
window logo + r
type
coreldraw.exe /s or /a for safe mode options.
Aug 01, 2010 | Corel DRAW Graphics Suite 12 for PC
When i try to save a coreldraw problem a message appears file copy error: temp or output drive may be full what is the solution
Is your computer's "C:" drive getting full?
Are you trying to save to a file on a USB memory-stick? Is that stick getting full?
Jul 03, 2010 | Corel AE CorelDRAW Graphics Suite 12 for...
I need to open a coreldraw 14 document for editing using coreldraw 12.
save your file in corel 12 format using corel 14 then open it on corel 12
Aug 31, 2009 | CorelDRAW Graphics Suite 12...
Corel draw is not open plz help me
coreldraw x5 (Portable Vertion) not opend.
Error :
The application was unable to load a required component :
CrlUtl.dll. Please contact the publisher of this application for more information.
Jun 13, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Mar 18, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Pinnacle Dazzle DVD Recorder Logo
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
