Question about Refrigerators
Whirlpool ice/water combo has impurities in water
I recently bought the Whirlpool GI5FXAXVB00 bottom freezer. When I get water from the dispenser, it's fine. When I get ice first, then water, it looks like there are little fuzzies in the water. I thought at first that perhaps it was ice particles, but I'm not convinced, since they stick around for quite awhile, instead of melting. Have you heard of anything like this?
I left the water/ice alone until the ice cubes completely melted, and the fuzzies were gone too, so I guess they are ice particles. It's a little weird, but at least I know what they are!
Posted on Jan 16, 2009
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
Whirlpool ice maker makes impure ice but the water is crystal clear and good. replaced filter and cleaned ice maker tray ect.... no change. Is there a way to sanitize the water line to the ice maker?
what you are seeing in the ice is the impurities in you water. you wont see them until the water freezes because you are trying to freeze the "H2O" and not the calcium and magnesium. those are what causes your ice to look cloudy.
filtering the water does help but you cant get perfectly clear ice with this type of an ice maker.
when you see "store bought" ice and it is clear, that is because it is made a different way to prevent the impurities from forming in the ice.
also the longer the ice is in your freezer, the more it will absorb from the air causing even more cloudiness.
Jan 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Nov 06, 2008 | Whirlpool GC5SHEXNS Side by Side...
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
