Question about Mitsubishi WD-62825 62" Rear Projection HDTV
WON'T TURN ON
Last december the co. took the t.v. replaced the lamp, fixed everyting it was under warranty. it was fine. turn on and the timer light blinks and the t.v will not turn on????
    Genius:
  • 1,153 Answers
Try to see if you can do a self diagnosis test and if not Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... of lamp replacement.
Posted on Dec 17, 2007
DO NOT BUY MITSUBISHI TV BUY SONY IS BETTER
Posted on Jul 06, 2008
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I turn the key but the car won't start. Thinking I didn't turn it enough I turned it again and it makes a weird sound. Turned the car off and back on and it worked fine. Then today I had...
If in fact you own a 2011 Tucson, it's under warranty. You're describing a malfunctioning brake/stop lamp switch relating to the traction control light and getting into park. The other problem needs to be diagnosed by a qualified/certified Hyundai Service Technician (probably under warranty). Phone your nearest Hyudai Service Department & take it in for warranty repair (or have it towed in using your Hyundai Roadside Assistance Service (no cost to you).
Aug 27, 2011 | 2011 Hyundai Tucson
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
I turned off my tv, and the next time I turned it on the lamp button came on red saying the lamp needs to be replaced. I just replaced it a year ago, and to look at it it looks fine. Could there be...
You need to replace the lamp and ballast to correct this issue, may sure use an original lamp from mitsubishi , generic lamp last less than a year
Dec 18, 2010 | Mitsubishi WD-Y65 65" HDTV
I have a Model ml 44t, when the temp outside became cooler my timer would not turn on the lights, it would stop rotating at the red post.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml44t%20trilingual.ashx
-I think your outdoor plug is connected to GFI plug in bathroom or kitchen >>> check reset on GFI.
-Next, plug your hair dryer into same outdoor plug to see if plug has electricity >>> electrical plugs outside wear out quicker, and get loose wires.
-Move timer cord to the other plug
-I don't know if a bit of WD 40 would help or not .... couldn't hurt to spry some on the pins at this point ...UNPLUG timer because WD is very flammable...
-Tips from manual mention checking for burned out bulbs ... I've seen that mentioned other places and don't know if bulb problems shorten life of low-volt transformer inside the box.
-I worked with timers for years, and never seen replacement clocks or transformers for Malibu-type timers
-Timers located outside get damp and dirty ... these things cause small gears inside timers to oxidize and clog so they don't work after a while ... again, a bit of WD-40 might help
Tips copied from manual:
• Make sure power pack is plugged in. Is outlet working?
• Turn manual ON/OFF switch to "ON" or rotate dial so "ON" tripper passes time line indicator.
• Is lamp burned out? Use another lamp to test.
NOTE: This lighting system is designed to last many years under normal conditions. However, lamps eventually burn out and operating with one lamp out can shorten the life of the others. IT IS IMPORTANT TO REPLACE BURNED OUT LAMPS PROMPTLY.
Conditions beyond your control such as abnormally high household voltage due to poor utility voltage regulation will also affect lamp life.
The timer has 1 year warranty.
Oct 04, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
Having trouble setting timer o ML200RT
Set on-off times by setting trippers
-Insert trippers
-Red tripper is ON
-Black tripper is OFF
-New timer has 2 sets of trippers
Set time
-Plug-in & turn-on power pack
Turn dial clockwise to set time of day
Manual override:
Turn manual-on-off switch counterclockwise
Troubleshoot:
-Power pack not turned on
-Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
-Manual-on-off is set to OFF > rotate to ON
-Outdoor lamp burned out > test with another lamp
-Important to replace burned out lamps promptly, or other lamps burn out quickly
-High household voltage will reduce life of timer
-Timer designed to last for many years under normal conditions
Sep 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I replaced the lamp after only a 14 months but it will not light up, then I put the old lamp back in and the lamp comes on momentarally but then shuts off and the TV never lights up. Why will the TV not...
Lamps last between 5,000-8.000 hrs Keep in mind every hour you play TV ,thats an hour lost on Lamp and its also possiable to receive a defective Lamp even new doesnt mean it works.
Lamp Fan if defetive can also prevent lamp from lighting. This happens to protect lamp from running and getting way to hot and therfore buring lamp up .
Ballast Board that connects to lamp is what turns the lamp on,if the ballast board is defective Lamp will not firer,meaning you either have bad lamp fan or new lamp is defective. Heres another Tip Sony had alot of problems with their Light Engines prices for that part range from $650.00 up to $2,799.00 depending on which light Engine you have? Since your TV is Still under warranty take it in quickly and be sure to ASK about warranty on YOUR Light Engine!!!
Jul 03, 2010 | Sony KDS-50A2000 50" HDTV
Optoma ep1690 projector lamp won't come on. Machine starts, fan starts but no lamp. only has about 100hrs used life. Lamp looks perfectly fine but LAMP inicator comes on then goes off. Should I buy a...
reset the lamp timer. if you don't hear a high-pitched whir when you turn it on, the colorwheel is bad. could also be the ballast. worst case, the main board. if it is under warranty, send it in.
Aug 19, 2009 | Office Equipment & Supplies
Light is blinking and tv will not turn on,.
If you say that you've had it only since last december, then it is still under warranty. Get it looked at by the Company Technician.
Aug 24, 2006 | Jensen Q2749J 27" TV
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
