Question about RCA 27F530T 27" TV
Channel constantly searching
My tv started searching by itself for no reason. Ater it would search for awhile, it would start shutting off and on. Then it may work for an hour or so, then start this process again. Nothing has been spilled near it and I am assuming I do not have a poltergeist, or at least I hope I don't! I don't have the RCA remote, just the cable remote. I decided to manually try and deltete all channels except 4, since that is the channel I use for the cable. My thought was if that was the only channel available, the tv wouldn't search. While I was doing this, I accidently hit something that said I think "fp4 lock yes", and my tv went off. Now I can not get it back on. Any ideas?
  • Shelly Clevenger Jun 16, 2007
    sorry, I didn't realize I posted this twice, I thought the first one didn't work. I obviously ahve no business near electronics!
#1 resolder cpu oscillator crystal #2 replace eeprom ic. #3 go to service menu set parameter "07" to "00" try one of these steps one at a time.
Posted on Jun 16, 2007
SOURCE:
Would ya know if this 2006 Oct. Memorex TV mod.# mt2024 is digital or not
If no one answers on that model TV (so many models), see following: All the digital TV's have a "search channels" function from a menu button either on remote or on front of TV. See if menu has something like "Setup" and "Auto Tuning" (or words like that) which indicates a digital TV, if no channel search likely analog TV. Once clicking to search for channels (arrow buttons to get there and enter button to start, or some other buttons I saw once did that), it scans the airwaves starting with Ch2 and ending with ch 78 or so. Takes about 30 seconds for it to find channels with antenna connected. Antenna can be old UHF antenna. Search completed, the TV can show the channels in normal channel viewing. If not a digital TV, you can get a DTV converter box to get free tv off the air, it is basically a digital TV tuner that works on analog TV's. You can get those on Ebay.
Apr 17, 2016 | Memorex Televison & Video
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have misplaced my owners phillips tv manual .I have moved my tv and need a manual to instruct me on how to re-tune my tv
Most tv's are as follows on your remote or tv hit the menu button, setup feature, signal type either cable or antenna make sure you select the correct signal type, the channel search and begin or start search. Select that option and it should begin to tune itself.
Feb 04, 2011 | Philips Televison & Video
How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Jun 01, 2009 | Televison & Video
Can`t receive all t.v. channels
get a menu of the tv and enter into a channel searching select auto and press search, automatically your tv will start searching. each signal found will be stored on each one channel.
later just store those channels into the memory of the tv.
Apr 29, 2009 | Bush 2871NTX 28" TV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Watching tv and it turn off
Please update this with a make and model number. WIthout that information there is little assistance I can provide. Also, does this occur all the time or only after the set has been on for a while?
Thanks,
Dan
Apr 08, 2008 | Televison & Video
RCA TV model 32V420T - Auto channel seek
Hi there!
Check that the remote buttons or the buttons on the Tv has not become sticky or soiled on the inside. Good Luck, JUS004
Mar 15, 2008 | Televison & Video
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
TV contantly searching
the keyboard has bad tact switches or the infrared detector has some issues. you can unsolder the keybard switches one at a time, or you can replace the whole keyboard with some of these models
Jun 16, 2007 | RCA 27F530T 27" TV
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
