Question about Sony Playstation 3 (PS3) Console
I cant play games online
My ps3 wont connect online,need to adjust router,assign dmz,port mapping etc
  • 54 Answers
You do not need a DMZ for ps3. jsut setup a SSID if wireless. Encrypt it (for your own saftly) and PS3 has wireless capablity. Just join the network with the SSID and WEP key and the PS3 will get an IP address. Also no port mapping is needed. Leave all port to auto open due to DHCP is going to get your PS3 a new ip every time you turn it on.
Posted on Jan 15, 2009
Im playing call of duty and cannot get onto any online games. I have an internet connection and im at the rank of lance cpl 2nd class but I cant play on any games?
Make sure that you NAT TYPE isn't moderate or strict if so factory reset the modem/router and if that doesn't do it, go into your modem/router via PC and set your PS3 as a DMZ host. NOT: Setting you PS3 system as a DMZ host puts your console outside the firewall.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
Weak connection
improve ur brodband connection
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
I can't play online ps3 games
it could be what type of router are you using? Are you able to sign into the playstation network? You could try setting up a static ip address on your ps3 and setting it as a dmz server. This will open up all ports for your ps3 and should enable you to play games. It should be a workaround for upnp. If you tell me what router make and model your using i can tell you how to do this.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I can play any game online fine, but when it comes to fifa i send my friend an invite he accepts then nothing happens it just comes up this game session is no longer active, or when i do get a game it says...
You need to either give your PS3 a static IP address and then put that IP in DMZ in your router, or you need to open up the ports it tells you in the Fifa 09 manual.
To put your PS3 into a DMZ (To be done on the PS3 Console)
Firstly, you will need to assign your PS3 a static internal Ip address. This means that everytime your PS3 connects or "talks" to your router, the router will assign it a different internal IP address. These IP addresses typically run in series. So for example, if your PS3 is the second device communicating with your router, then it will be assigned an ip address of 192.168.1.3. However, if you choose to use your PS3 without the computer being on, the assigned IP address your PS3 has will be 192.168.1.2. As this is different, and obviously will change, it would be stupid setting a DMZ up on one of the above Ip addresses, unless your PS3 was the only device that would ALWAYS connect using that specific IP.
To make sure that your PS3 is always assigned the same internal IP address by your router, you will need to go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 Cross bar menus.
You will be presented with an option which primarily asks whether you are using a Wired or Wireless connection. Obviously, you will choose the option which refers to you. If choosing the Wireless option you will need to input the security details in use on your router *If you are not currently using wireless security, i strongly reccommend you do so ASAP*
Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
This will display a page where customisable IP Addresses are available to be selected.
IP Address - This will need to have the Static IP address in it. Personally, i use 192.168.1.100. I use this because it is extremely unlikely my Router will ever automatically assign this IP Address to a device, as i will never have 99 other devices connected to the same system.
Subnet Mask - Is always set to 255.255.255.0
Default Router - Is the internal IP Address of your router.
To get the exact ip of your router you should go to
Start
Run
cmd [Hit Enter]
Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
Primary DNS - Same IP Address as "Default Router"
Secondary DNS - Same IP Address as "Default Router"
After entering all of these IP Addresses, you will now click "Enter" or hit the "right" button on the D-Pad. This will take you to a screen which says "MTU" at the top. My setup has this as Automatic, solely because i haven't a clue what MTU actually means or does.This won't affect your ability to set up a DMZ.
The next steps are very simple. You do not want to use a proxy server unless you connect to the internet using one, however i can be of no help there, and you should enable UPnP if your router supports it.
To put your PS3 into a DMZ (To be done on the PC)
Now head over to your PC, and load up your internet browser. In the Address Bar, type the IP Address of your router (the one you found using the Command Prompt earlier)
This will take you to your Router Configuration Page.
Every router interface differs from an other, and depending on what router firmware update you last installed, router interfaces can differ, even on the same model routers. This means that you will need to search the router config page yourself. You are looking for any mention of "DMZ" or "DMZ Host"
When you have found this, it will ask you generally to input the IP Address of your DMZ Host, which is just the static IP address you assigned to your PS3 earlier, my example was 192.168.1.100, so we'll stick with that. Then click "apply" or similar.
You should then turn off everything running on your home network. PS3, PC, Router etc. This is solely to make sure that the changes are applied as soon as possible.
This should fix all of the problems as listed earlier in this guide, and probably some other issues
May 19, 2009 | Sony Playstation 3 (PS3) Console
Pro evolution soccer 2009 online problems...ps3
I had the same problem. On the main options menu if you go down to the bottom theres an option for system settings or something like that. In here you can change the port settings. By default its set to port 3658 or whatever. I change it to the auto assign option and now its working fine. Hope that helps.
Mar 30, 2009 | Konami Video Game Consoles & Games
Ps3 can only connect to one or two games online playing fifa09
I'm not sure about 3659 but these are the ports I have forwarded
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
Also DMZ would be perfectly fine as long as long as you set a static IP on your PS3
What DMZ allows is that any ports communicating to a specific IP access, so if this IP is alway connected to your PS3 no harm to other computers or devices can be done!
Dec 02, 2008 | Sony Playstation 3 (PS3) Console
Unstable PS3 connection
good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
Feb 27, 2008 | Linksys Wireless-G WRT54GX Router...
Playstation 3 lag issues
if u haven't already , you may need to adjust your router settings
1. enable UPnP
2. enable DMZ
3. change ip settings from dynamic to static
4. check out game sites as may have to port forward some ports
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
