Question about Linksys : WMP54GS Wireless-G PCI Adapter w/ SpeedBooster (NELIWP16)
Cannot get wireless working on vista
I have a dual booting pv with xp and vista on xp my wireless card is working fine but on vista I get connected with limited or no connectivity. I also checked to update the driver and my linksys is showing as a broadcom in vista but when I load the drivers from the cd it stays as the same driver and says it's up to date. I am only 20 feet from the router and I am using wep encryption and do not have a 2.4Ghz phone interfering with the connection.
  • 14 more comments
  • Jennifer_H Jan 15, 2009
    I'm not sure what you mean I set up the connection through the vista program as when I installed from the linksys cd there was no linksys configuration tool. So I used the vista one I set up the wireless network manually as well as connecting to the broadcasted ssid.
    oh it is dual booting
    I have already tried that the driver is installed and correct I can connect to the network but it says limited or no connection. I have tried all the drivers used for this card for vista and have the correct one installed is there another way to get it to work? I thought there was an issue with tcp/ip settings so I tried setting a static ip and i got the same message.
    I am able to ping the router but not google
    sorry I meant I can ping the router but at 4 packets with a 100% loss and can not ping google at all, I am not able to run a patch cable to this computer at the moment but I have tested with one and it does work
    I have repaired several time to no avail just the same thing I have also set a static ip address with the same problem
    the router ip is 192.168.2.1 with a range set from 192.168.2.1 to 192.168.2.99 and i assigned 192.168.2.3 as the static ip
    yes as well as standard comcast dns
    yes i can when I am on xP but not on vista
    yes still nothing im going to see if I can connect by turning off security to the router and see what happens
    yes but i am going to try with security disable to see what happens
    ok well I have it set to dynamic ip and I am online on vista now but there is no security on my router now and I do not want to leave it unprotected
    wep key apparently was the problem is there another way to make sure my router is safe from unwanted guests/visotors
    I have tried using all numbers same problem I also tried wpa is there a way to secure the router through mac address filtering?
    it seems to still be working now but will the mac filter keep others out or will it just add anyone who connects to my router add its mac adress to my filter list?
    ok thank you for your help I will ask you again if I need more help
    Problem Solver:
  • 29 Answers
No problem at all.
Posted on Jan 15, 2009
  • 54 Answers
Physical to Vitual Vista? if it is a virtual setup the xp machine will latch onto the nic card not giving it to anything else. what Virtual emulator are you using? There are settings that have to be set to allow the local nic card to be used.
  • 12 more comments
  • Stephen Horan
    Stephen Horan Jan 15, 2009
    I am asking you is it a Dual boot or is it a Virtual Vista?
  • Stephen Horan
    The driver is sometimes different for vista then it is for XP. Try going on you Manfuacturers website and downloading the Vista version of the driver. This is a common mistake that people make being that vista handles drivers alittle differently then XP did. However some drivers work perfect with eachother while some of the others do not.
  • Stephen Horan
    Open up the cmd prompt and try to ping your router. if sucessful try to ping google.com and let me know what you come up with.
  • Stephen Horan
    Can you conenct with a patch cable. LAN connection not wireless and test to see if you have internet.
  • Stephen Horan
    You are not recieving an IP address trying rebooting or doing a repair on the connection
  • Stephen Horan
    what static IP address did you give it?
  • Stephen Horan
    do you have the subnet mask set at 255.255.255.0 and the gateway as 192.168.2.1
  • Stephen Horan
    can u get into the router to access it?
  • Stephen Horan
    Did you try allowing it to assign an ip automatically again and still nothing?
  • Stephen Horan
    Also make sure there is no firewall on the router that may block it and try adding a static router to you vista computer using the MAC address to IP. This way it will automatically assign you a static IP address every time you log on.
  • Stephen Horan
    Give that a try let me know what you come up with
  • Stephen Horan
    Your problem is the wep encryption then. Try just using wep key by itself and makin it 8 bits long and all numbers ex: 12345678
    because wep gets converted into hexadecimal anyway.
  • Stephen Horan
    I would set that so your computer is allowed only if the MAC address is on the list. I am going to say yes give that a try. Your router may only allow people of that list if secuirty is set to active.
  • Stephen Horan
    Its only going to allow you to access it as a means of security. Once you add another MAC address though they can stay on at all times.
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
Panasonic PV-DV402 with Windows Vista
hi there
you can try and check panasonics home site for compatibility issues regard there products to windows vista.
hope this would resolved your problem.
Jan 29, 2008 | Panasonic PV-DV402 Mini DV Digital...
XP safe mode problems
you could try editing the boot.ini to switch the vista install and xp install.
try this
http://news.softpedia.com/news/Windows-XP-Fails-to-Start-After-You-Install-Vista-In-Dual-boot-Configuration-47906.shtml
Mar 14, 2009 | Dell XPS M1530 Laptop
Video card not working with xp sp3
The drivers for XP and Vista are different. You will need to install the drivers for XP as well as Vista for dual boot operations. Make sure you install the XP driver in the XP partition and the Vista Driver in the Vista partition. This should solve the problem.
Dec 20, 2008 | Computers & Internet
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
I need the VGA DRIVERS
geokohler
Rank:guru_s.gif Guru
Rating: 86%, 113 votes
Please tell me the make and model of your computer and what operating system you are trying to run. I have access to all the drivers for every make and model and I will send you the link where you can get them once you send me the information I need first.If your computer came with Vista there are no drivers for your wireless card or your VGA card for XP. If you want to run Xp you can partition your hard drive into 2 logical drives and load Vista on one and XP on the other in a dual boot configuration. Then you will need to purchase an external USB wireless thumb adapter for accessing your wireless networks when you are using the XP operating system. When you boot in Vista your computers wifi will work fine. The hardware manufacturers are being forced by Microsoft not to release drivers for XP for new equipment under threat to pull licensing for Vista. This is the only way to get around it, unless you are capable of writing your own .inf driver files for the hardware. If you need my help feel free to contact me and I will help you further. This is Microsoft's way of strong arming everyone to migrate to Vista. I run dual boot configurations on all my equipment because some of my expensive tech software only runs in the XP environment. Vista is a powerful operating system if you have the equipment designed for it. It's a shame they removed so much of the backward compatability though. My e-mail address is geokohler@gmail.com if you need more help send me your number and I will call you for free to discuss your options in more detail. Please take the time to rate this fixya and I will provide you with free support whenever you need it directly. I do this for a hobby, I just like helping people.
George
Aug 30, 2008 | Computers & Internet
WI-FI not working
If your computer came with Vista there are no drivers for your wireless card. You can partition your hard drive into 2 logical drives and load Vista on one and XP on the other in a dual boot configuration. Then you will need to purchase an external USB wireless thumb adapter for accessing your wireless networks when you are using the XP operating system. When you boot in Vista your computers wifi will work fine. The hardware manufacturers are being forced by Microsoft not to release drivers for XP for new equipment under threat to pull licensing for Vista. This is the only way to get around it, unless you are capable of writing your own .inf driver files for the hardware. If you need my help feel free to contact me and I will help you further. This is Microsoft's way of strong arming everyone to migrate to Vista. I run dual boot configurations on all my equipment because some of my expensive tech software only runs in the XP environment. Vista is a powerful operating system if you have the equipment designed for it. It's a shame the removed so much of the backward compatability though. My e-mail address is geokohler@gmail.com if you need more help send me your number and I will call you for free to discuss your options in more detail. Please take the time to rate this fixya and I will provide you with free support whenever you need it directly.
George
Aug 19, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Running daul boot xp pro & vista ultimate os and I use the v740 express card for internet. In xp pro the card works fine, In Vista ult. I had service up to when I did the update through verizon access...
turn off your computer. disconnect the cord wait about five minutes. this should help the system reboot itself and try logging on again. I hope this helps and works.
Mar 06, 2008 | Computers & Internet
USB drivers for Vista
Panasonic only lists XP and older drivers and no mention of Vista. We have the same problem with a couple of our older cameras (HP) but they were up front and told us they weren?t going to develop drivers for older consumer items. You might want to consider just keeping a PC running XP (or setting up dual boot) for your camera until drivers are released or you give up waiting. Not the answer you wanted but I think its probably the most practical and gets you running now.
Jul 21, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
Drivers to use
If you really want to keep on using this old 640x480 camera, why not look for some cheap old notebook with Win95 installed?
Sep 06, 2005 | Panasonic Palmcam PV-DC1000 Digital Camera
Computers & Internet Logo
106 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
