Chemical smell from electric hot water tank
Very strong odor
  • Anonymous Feb 19, 2009
    Moved into a new apt. and there is a strong chemical odor coming from the hot water (only) from every faucet in the house.
  • 30 Answers
Switch off immediately and call electrician
Posted on Mar 26, 2009
2004 Taurus has strong chemical smell
The tank is loosing coolant because there is a leak somewhere in the cooling system. I would have the system pressure tested to verify there is a leak. Sense there is a odor in the car and the coolant is low ..I would suspect the heater core is leaking. A pressure test will help locate the leak in the system.
Nov 19, 2012 | 2004 Ford Taurus
My turned on the kitchen cold water tap last week and the smell of petrol that came out was over powering ! It's still very strong I don't know what to do ! How do I clean it is there a chemical I...
Unless a petroleum product was poured into your well or the ground water around it was contaminated with it and it leeched into the well water, I suspect the odor you smelled was a high mineral content odor. This sulfur odor is often associated with the deep artesian wells and can be rather strong. Normally, it's caused by a seasonal change in the underground water table. If you didn't get the odor from the hot water tap, that's an indication, that when the water is heated to a high temperature the odor dissipates. But, to be on the same side, I would recommend that you have you water supply tested for contaminants. Generally, your local health department or a water testing company can do this for you. If it's what I think it is, the well can be treated.
Hope this helped to address your concerns,
May 05, 2011 | Heating & Cooling
Ice smells/tastes like chemicals
discard ice keep making it till it goes away(dont eat ice) if doesnt go away-further investigate!!! :)
Jul 06, 2009 | Hotpoint HSS25GFP Side by Side...
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Fridge has chemical smell
The smells are being pulled in through the air intake from the fridge from the chemicals they used on the floor. As the coating cures, the odor will end. As for the damage to your food and drinks? I would assume if the food tastes like the chemicals, I would avoid eatting them if you do not like the taste )
Apr 06, 2009 | Hotpoint HSS25GFP Side by Side...
Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Mar 14, 2009 | Refrigerators
Chemical odor...
from where does the smell come?
inside the unit or from the body?
does the smell spread to food items?
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Chemical odor...
Is the unit working ok I think tech17 is trying to find out if you have a freon leak inside the unit??
Jan 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Plasma TV smell?
i had the same prob and thought it would burn off. It didn't after a month. Read the comments and tried the plug direct into wall socket plus i washed off the tv surface several times. Now no smell. Not sure which action cured the problem but i'm now happy. It was so bad i had to leave a window open and at times i would gag from the smell.
Jul 20, 2007 | LG 50PX5D 50 in. Plasma HDTV
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
