Question about Hoover U5163-900 Upright Vacuum
VACUUMING FOREVER? It sucks up great, but throws quite a bit out the back. You vacuum, and vacuum! I have to redo everything since it spits a lot out the back, you turn it around to vacuum it up, and has thrown out more behind? It seems to be a unending nightmare. I check and make sure the basket is emptied frequently, and that doesn't make any difference. I have birds that are messy, and need frequent and quick pick up, but has problems with seeds. Small amounts of cat litter on floor, that it really throws out behind, and is absolutely useless for that use. Is cat litter a no no? Just everyday dirt or whatever it throws out behind it as I'm vacuuming?
  • 2,985 Answers
Looks like a filter has slit or gone missing on the exhaust side of the motor.-or perhaps you did not know there was one - it has clogged and a bypass is operating. You will have to consult the handbook for your model re filter changing to sort it. The Hoover Web site may be a help - have you looked?
Posted on Jun 16, 2007
0 characters
3 Points
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
My sanyo power brush is spitting out dust instad of sucking it in
Check for a plugged hose or wand, this is a classic sign of a plug some where between the power head and canister.
Sep 24, 2009 | Sanyo SC-X1000P Canister Vacuum
EUREKA Bagless altima shooting out debris and not picking it up
did u clean the filter? if u get a new one i would suggest a kirby. bu get a self-propelled model. THEY LAST FOREVER!!!
Jun 15, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
is brushes moving, if so it is clogged , usually takes a star bit to take apart to clean
Feb 07, 2009 | Hoover U5753-900 WindTunnel Bagless...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Home healthy bissell vacuum
your intake hose is clogged.its the clear hose that comes up from the bottom and up the backside of ther vacuum.take the screws out that hold the hose connector on and then take a coat hanger and bend the tip so it is round then work it down into the intake might be able to push the clog out the bottom
Dec 19, 2008 | Bissell Healthy Home HEPA Bagless Upright...
Bissell bagless
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Oct 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Filter queen spitting more than sucking
Usually this means that you have a clog, either in the hose, wands, or by the brush roll in the power head.
May 05, 2008 | Filter Queen Majestic Canister Vacuum
Won't suck up water from floor
1. Check all the tubes from the nozzle to the collection tank and make sure they are not clogged up. I've had tht happen pretty bad before. 2. Check the squeegee. If it is damaged or torn, replace it.
Aug 27, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U5163-900 Upright Vacuum Logo
310 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
