Question about Hoover F7431-900 SteamVac Vacuum
Brushes not working
Everything works good except brushes will not turn and the brush switch is turned on
  • Anonymous Apr 12, 2009
    Do you have a rough description of how to open the turbine?
    Thanks
  • 294 Answers
Brushes not turning are usually caused by the turbine bearings have seized. The turbine cost is about $35 average. on the bottom you can check a pull out filter to clean. there are also 2 screws that are recessd check by hand for tightness that hold the turbine. checkthe brushes for cleaning and free of debris. check the square shaft on the brushes as well. take it to a trusted vac shop who works on hoovers if you are not mechanically inclined for this type of repair.
Posted on Jan 17, 2009
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson Telescope vacuum. Everything works fine, except the attachment used for floors. I can feel air and suction going through the attachment, but the brush doesn't rotate or move at all....
If you have suction as you say, the tool is faulty.
They come apart so you can clean them. remove all hair and debris from the roller brush (use a coin to split it using a quarter turn on the two/three screws). Try turning the brush with your fingers. If it is stiff, it needs attention to the bearings in the tool probably. If it turns OK, then the mini turbine inside is faulty -- replace the tool.
Feb 05, 2011 | Dyson DC14 Telescope Reach All Floors...
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Steam Vac with Clean Surge model #F50905-900
All you need for your item is the belt.dissassemble the unit and you will se the track where the belt was, or even the old ne snapped an trapped somewhere inside. brush assembly purchase will not solve this.
update me about your progress.
Good luck
Jun 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Healthy Home Vacuum Cleaner
sounds like you need a new belt for your agitator(brush)
Jan 26, 2009 | Vacuums
Brush motor quit
The beater bar belt is broken.
Nov 18, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
630 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
