Its in the owner manual but generally:
Unplug the set first
remove plate beneath screen on front of set, usually pulls out or has a thumb wheel on either side on rear to back out first.
Locate the Lamp Door directly behind it and remove the screw/s that secure it.
Inside you will find the lamp cartridge, back out the two screws until the cartridge is free, and pull cartridge out by the handle it has.
Do not just buy a bulb unless you want a darker picture and a short lamp life--get a replacement with the cartridge.
A word of caution, when you slide the new one into the set take care the two pins on the lamp line up perfectly with the socket in the set where the lamp goes, it is easy on these sets to have the lamp not engage and bend the socket in the set out of position, it can be dealt with but easier to avoid that pit fall.
Door and plate and all screws etc and power set up to see what you have.
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Testimonial: "very helpful. this was my first thought! thank you!"
SOURCE: How do i open the housinf for a Wd-65733
Just take all the screws out in the back,make sure all screws out.Just remove the cover.
SOURCE: Mitsubishi wd 65733: new bulb, 1 month ago, worked
The only thing that could cause the yellow light to blink after the new lamp is that the lamp lid or access door is not placed correctly or there might be some debris between the door and the door seat to where the door sensor switch is not being activated or the switch is erratic. Try using some compressed air to clean the switch and the door seat, that might do it for you. Thanks!
SOURCE: I have a Mitsubishi WD-65733 DLP TV and we have
I have the same problem with my Mitsubishi WD-65733 DLP TV at first when the problem started the screen will turn on normally then go black and u can hear the the TV..Now it turns on but black screen and still could just hear it but then it just shuts off, somebody please help...
