Question about Reddy Heater-30-55,000 BTU Variable
Unit will not fire off when switch is turned on (kero unit)
Unit shows no life. We have several others and when you cut them on the burner fires. this unit does nothing.
TNX
Steve
I had the same problem and removed the heat adjusting panel and removed the two wires from the knob terminels and spliced the wires together with a wire nut and electric tape and the unit worked fine
hope it works for you as well
Reagan
let me know your results
Posted on Jan 17, 2009
Basicly I need the repair shops near Albany, Ga. I E-mailed reddy but have not heard from them
Posted on Jan 16, 2009
Two weeks ago my base board system oil burner shut off and would not restart.
guessing the thermacouple may be failing as this part tells the fuel metering system if the burner is hot enough to maintain safe combustion
Dec 09, 2017 | Heating & Cooling
My goodman furnacs says my limit switch is bad blower works but does not ignite .....? its modle gmt070-3 and where is it located
There are several limit switches in the unit there in various places in burner compartment. One on blower housing . One thing that I would try is replaceing your filter and turn the power off to the furnace and try starting the system after power is D/C for 5 minutes.
May 02, 2011 | Goodman GMS90703BXA Heater
30roof top unit combustion blower comes on but does not ignite ignitors are new
Hi, when the combustion motor comes on, it should or will have a poly type tube on this motor that runs over to a pressure switch. This switch is where the other end of the hose connects. These switches get stuck open at times and have to be broke free by removing one end of the tube and blowing through it. This is a silver looking switch, could be different, but the contact in this switch will stick open causing the unit not to fire up. There is a sequence of operation on these units, 1st the combustion motor will pressurize the box and send pressure to the switch which closes. Once the switch closes, it will send 24 volts to the ignitor module to open the main gas vale to fire the burners. This is just one of several safety switches. This will solve your problem. You can also check this switch by jumping across it with a piece of insulated wire from terminal to terminal. It will fire right up.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 07, 2011 | Heating & Cooling
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Unit will try three times to start then shut down
Make sure the exhaust fan is running.You say it fires up and then cut off.Does the main burner come on just the pilot?If it's just the pilot then I would say you need to replace sense that senser the pilot lite.Because onces that senser the flame the main gas vavle should open.for give me for my mis spelling.
Mar 26, 2009 | Heating & Cooling
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Dayton kero heater wont fire
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Jan 15, 2009 | Dayton Electric Heater
Reddy Heater-30-55,000 BTU Variable Logo
70 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
