Machine flashes f-08 code and stops wash before rinse and spin. If i leave the machine off over night and take out half the load it will rinse and spin the next day. Very annoying when you have kids and a constant stream of dirty laundry. Is this a terminal problem or can i sort it out at reasonable cost.
-   i have a hotpoint aquarius wf740 and a message f o8 can some one help-   andrewmhw58
Mar 11, 2009
-   Similar problem - did the suggestions posted work? ie. heater relay or whatever the other thing was & was it expensive to get repaired.-   paddyd63
machine did not end cycle, got stuck before spin cycle for long time. switched of and put on...
(More)
machine did not end cycle, got stuck before spin cycle for long time. switched of and put on "spin &rinse" cycle. Then a lot of lights started flashing
Aquarius wf541. Am trying to unscrew and remove pump filter at front to clean and check for...
(More)
Aquarius wf541. Am trying to unscrew and remove pump filter at front to clean and check for blockages as lights keep flashing. Kick plate removed ok. turned filter anti clockwise as oer instructions but it will not remove. any ideas? have tried pulling with pliers but dont want to use too much force incase plastic breaks
