Question about RCA OPAL M4001 MP3 Player
My mp3 player will not charge or come on.
Usually when i plug it in it use to work now it will not come on at all nor will it charge.
  • Anonymous Jan 17, 2009
    will not come on or charge when i polg it in
  • 8,596 Answers
Disengage the hold switch on the side of the player.
Posted on Jan 17, 2009
How long do new mp3 players need to charge up the brand name is eclipse 2810c
Keep the MP3 player plugged in until it makes an alert or starts up. It usually is 1-2 hours but I would check the manual! :)
Jul 30, 2012 | Philips Audio Players & Recorders
How do you charge the battery?
MP3 players are usually charged using the supplied USB cable. Connect the USB cable to the MP3 player and then plug the other end of the USB cable into the USB port of a working computer.
Jun 01, 2012 | SanDisk Sansa c200 MP3 Player
My mp3 player is only working while it is plugged into the pc, how do i get it to work without a pc?
This problems seems to be with the battery on the MP3 player. Either it is not holding the charge in the battery and not allowing you to use it without a power source (in this case the power is from your computer). Try plugging the MP3 directly into the outlet instead; leave for 1-3 hours to charge and see if the battery it taking a charge. If the MP3 needs a repair; I used the www.cpr-nyc.com repair center and they can usually fix those type of problems.
Good Luck
Paul
Jul 05, 2011 | Cameras
How do I charge the battery in my Lexas MP3 player. I thought all I had to do was plug it in to my computer and it would charge that way. But that doesn't seem to work. Do I need software or something?
Just need the drivers downloaded. You can usually get them from there website. Just download the drivers, then double-click on the file once downloaded so it installs into your pc. Then restart your pc, then plug in your mp3 player and you should be good to go!
Jul 11, 2010 | Lexar LDP-600 MP3 Player
The mp3 player won't charge when I plug it into the computer and my wife's won't accept any more playlist
I dont know about the playlist. But if the Sansa LION battery goes too low it shuts down. When you plug it into your computer to charge the player, It usually powers up so the computer can detect the hardware being plugged into the USB port and provide power for charge.
You need to plug in the USB cable from the player to the PC and perform a system reset - Press and hold for 20 seconds the power on button and the play button (>||). this should work you may try it on your wifes player?
Feb 06, 2010 | SanDisk Sansa Clip MP3 Player
Did not receive manual. How do you recharge
Simply attach the USB plug that came with the device to your MP3 Player, then plug the other end into a computer, it should automatically start charging! A full charge usually takes about 2 hours.
Hope this helps!
Dec 25, 2009 | SanDisk Sansa e250 MP3 Player
I don't know how to download music into the GoGear VIBE mp3 playe
Usually most mp3 players work as a flash drive when you plug them into your computer. Some won't let you transfer or play while charging, but this one looks like it gives you an option to.
Open Windows Explorer (to see the drives, folders and files) and plug your mp3 player in. Select Charge and transfer. A new Removable Device should appear in Explorer with a drive letter assigned to it. It could be F:, G:, H:, etc... Just copy your mp3s onto that drive.
When you are finished, clock Safely Remove Hardware in the bottom right corner of your screen and select the mp3 player device and stop it. A message will appear saying that it is safe to remove this device. Then unplug it and enjoy!
Aug 17, 2009 | Philips GoGear HDD1830 MP3 Player
Charging MP3 Player
Usually ya simply plug it into the USB port, that "Charges" it up.
Have a squiz at a ya manual.. see if it tells ya there?
Jul 28, 2008 | SanDisk Sansa c200 MP3 Player
Not working.
I have no charge in my philips hdd82 player. Usually I just plug it into my computer via usb and a screen shows up on the player showing its connected and it charges. Usually it comes up as an MTP device on the computer so I can add mp3s as well. Now for no reason at all, when I plug it in, it doesn't charge and the computer doesn't recognize it. The screen shows an outlet when I plug it in so I know the cord works. It just won't let me do anything. When I press the on button with the cord unplugged, I can't do anything either b/c no charge. HELP. plz.
Nov 16, 2007 | Philips HDD082 MP3 Player
Ilo mp3 player won't turn on
Ok, SOME MP3/4 Players indeed charge from the USB port, albeit slowly... usually tho there comes a charger that plugs into the "Mains" and then plugs into the USB socket on the Player.. Sometimes if the Battery goes really "Flat" the USB port is unable to supplu enough "Current" sucessfully charge it up. (Hence the need for wall charger) IF it was entirely Via USB it would take many hours, I would at least think overnite. Hope that hepls.
Jul 30, 2007 | iLO (2 GB) MP3 Player
RCA OPAL M4001 MP3 Player Logo
50 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
