Question about Sony Cyber-shot DSC-W50 Digital Camera
Image size too small - even when set on 5 MP
When photos are downloaded to computer, they all end up between 1-2.2 MB in size, although pictures are being taken at 5 MP size. Talked to Sony support twice, resetting to factory defaults didn't help. All pictures are SMALL, no matter what I've tried. It's been doing this since I got the camera, > 1 year ago, so of course the warranty is over, and repair costs don't seem worth it ($181 + shipping...)
  • 102 Answers
Hi, Although I prefer you getting it repaired, but there is a slight chance to get it working. 1) First you have to go through every single option in the Camera and change it. 2) Try using the Built-in memory instead of the external if you got any. 3) There is an option for the Picture quality, as "Standard, Fine, SuperFine". Try changing it. 4) Try using it on anothe PC just to be sure. If none helped, then a hardware component must be replaced, because there is not firmware update/upgrade. Good Luck
Posted on Jun 18, 2007
SOURCE:
I have my S610 set to take photos @ 5MB. But when I download them to Picassa, they are ~1.2 MB. Is this a camera setting or Picassa?
Neither. The camera is taking pictures at 5 megapixels resolution. The file size of the image is only loosely related to the resolution. You'll note that your pictures are all different sizes. The size is dependent on the content of the picture. If you take a picture of a blank wall or a plain blue sky, the file size will be smaller than the file size of a picture of a cluttered scene, because it takes more bytes to record detail.
If you look at your pictures in your image viewer, you'll see that the pictures are all the same dimension (width and height), regardless of the file size.
May 15, 2011 | Cameras
My images save at sizes of 3-4 MB!!! how can i get them to be (way) smaller files??? powershot SD790is digital elph
Your solutions are varied, but the results will be (mostly) the same. Option 1: Lower the resolution and quality settings on your camera. If you are seeing 3-4 MB per photo, then they are probably at least 4000 pixels wide, and your file size will be larger to reflect that. If you set the camera to a lower quality and or resolution, you will for sure save disk space. Consequently, you will also lose image quality. If you are mainly archiving the photos for the purpose of viewing them online, on your PC, or through a digital picture frame, this is no big deal. If you intend to print, especially a large print, you will see pixelation occur in the print. This will take smooth parts of your picture and chunk colors together in a "boxy" appearance. Your second option, is to import your photos in a program like Google Picasa or many other free options, and then convert your image to a compressed format, such as a compressed JPEG or PNG file. PNG files are usually the better choice for file size, but not every devices (frames, TVs, etc.) recognize PNG files. So you may want to stick with JPEG depending on your use for your photos. Additionally, you can lower the resolution of hi-res photos within Picasa (or its alternatives) after importing the photos. This is the preferred route as you can take every photo like you want to print it as a poster, and then choose which photos to drop the resolution. This gives you the safety of shooting each picture as if you want to keep the quality and then later decide which are worth archiving at what resolution. Remember, the detail in a photo also reflects upon its size, not just resolution, if you take one 12 MP picture of the sky and another of a bunch of different color balloons, the balloon will have more color data and thus a higher file size.
Mar 10, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Hello, My camera had been taking photos under a file size of 1 MB, normally 800 KB. Today for some inexplicable reason (I must have done something!), the photo file size is 4MB, too large to send and use...
On your camera, look for settings. You must have set it on "Large" or "Max" picture quality. Thus making your 'normal' 800kb into a more better quality.
On your laptop/computer try to open it in a image editor and change the resolution of the picture.
Dec 14, 2010 | Sony Cybershot DSC-T200 Digital Camera
The internal memory is full; how do I correct this?
Delete pictures until it is empty. Use a higher capacity memory card and switch to it in the menus.
How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Question : How many pictures can be stored on the internal memory of the KODAK EASYSHARE-ONE Zoom Digital Camera? Answer : The camera has 256 MB internal memory (185 MB available for image storage)*. The number of pictures that can be stored depends on the Picture Size (picture quality) setting selected on the camera as well as the level of detail of the subject. The following information can be used to approximate the average number of pictures that can be taken at each setting: 4.0 MP: 150 pictures 3.5 MP (3:2) : 167 pictures 2.1 MP: 270 pictures 1.1 MP: 451 pictures NOTE: Internal memory can store up to 1500 images, tagged as Favorites, optimized for viewing on the camera. Favorites as such are added to the camera through synchronization with EASYSHARE Software on your computer. See the camera user's guide, or click the Help button in EASYSHARE Software for more information.
*1 MB equals one million bytes, 1GB equals one billion bytes
Aug 03, 2010 | Kodak EasyShare One Digital Camera
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
Picture file sizes...
Hi Gixerjames
The short answer is NO, I think, unless you set the camera to take small file sized images.
What do you mean by small by the way? Sounds like you have a specific purpose in mind but remember small "file sizes = less detail".
Is resizing a big chore - there are plenty of freeware utilities out there to do batch resizing if you find resizing tedious for all you images.
Regards
Martin
Aug 26, 2009 | Nikon Cameras
How many pictures can a kodek easy share m1063 take without a memory card
In your menu you will have a choice of "resolutions"(picture size) such as 9.0 mp,8.0 mp,6mp.8mp,5mp,3.1mp,2.2mp,2,1mp,1.2mp. The small the size(and poorer quality) that you choose, the more pictures you will be able to take. Your camera prob has internal memory of 32 mb and when you have selected your picture size it should show on the screen how many pictures you are able to take. Mine for instance will take 5 photos at 9 mp but 16 at 3.1. It really is worth having a spare memory card at all times to enjoy your camera fully.A 2 gig card gives over 1000 photos at 9mp.
Jun 12, 2009 | Kodak EasyShare One Digital Camera
Pictures
It depends on the quality of the image and the number of mega pixels at which you shoot photos. HP Photosmart M517 shoots at up to 5 mega pixels + there is an additional setting called "5MP Best". 5MP setting creates images that are around 1.5MB - 3.5 MB in size. So, assuming 2.5 MB as an average, you'll get around 52 images per 128 MB at the best possible quality. You can do the other math. However, the camera always displays an "estimate" of how many more pictures you can take.
Now if you want to increase the number of pictures you can take you should decrease the image quality. 5 MP regular might give you upto 64 images per 128 MB, 3 MP may give you uptp 128 images per 128 MB (these are all approximations that evaluated based on my experience with this camera). I suggest that you don't go below 3 MPotherwise you'll get images that look OK on screen but not good for printing.
Aug 09, 2008 | HP Photosmart M415 Digital Camera
DSC-F717 mp Question?
do you mean your files are around 2 mb (megabytes) in size? megabytes and megapixels are not the same thing..megapixelspixels=resolution and megabytes=file size..5MP pictures are around 2MB in size..
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
