Question about Canon Rebel XT / EOS 350D Digital Camera
Err 99 on canon rebel xt 350 d
My camera was fine and working beautifully on night. the next day, err 99 and nothing when i would try to use a flash. only in no flash mode was i able to make the shot.
  • 1 more comment
  • Anonymous May 14, 2009
    same, exactly
  • Anonymous Mar 23, 2014
    When I turn it on it displays err 99
    When I turn the canon on it displays err 99
    Problem Solver:
  • 8 Answers
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Posted on Jan 15, 2009
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Canon EOS Xt displays Err 99 how do I fix it.
change the lens or try cleaning the connector tabs with a eraser.
Jun 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flash Problem
Hey tombston,
An error code of 99 is Canons general error code for this camera, and they suggest cleaning the lens contacts and/or removing the battery and then reinserting it. If this doesn’t work I would try resetting the camera to the default factory settings, and directions on how to do this are on page 35 of your camera manual. If this doesn't work I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of the camera manual in case you need it. I hope this helps!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT will not work with new faster CF cards.
Check the volume and speed of memcard, maybe it is not compatible. error 99 is an indication that a lens or shutter curtain is not working, so i cant see any connection with the memcard problem. Check your camera memcard compatibility.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 only when flash pops up
I know what you two are talking about. I ordered a Canon EOS 300d from a site called "Keh" and I had never used one before... so I get it in the mail on time. The camera works fine for a few minutes then I get an "error 99" and can't do jack with the camera. I researched online and even called keh ... I read and heard that it has to do with the lens... so I sen't the camera back and got my money.
Nov 26, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
370 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
