Question about Kenmore Oasis HE 27082 Top Load Washer
Control Board failure
I purchased a Kenmore Oasis washer on May 17, 2006. It never worked as efficiently as I was lead to believe. About two weeks ago I began getting an F-1 error light. When the technician arrived I was told that the control board had failed, and the cost of repair would be $376.28. When I checked the internet I found that this was a very common problem. The failure of this part is the result of faulty design, engineering and manufacture, and should not fall onto the consumer. When I notified Sears, their response was curt and unfriendly, "Tough luck, out of warranty" I got no better when I spoke to Whirlpool. I intend to join the class action law suit to remedy this problem.
    President:
  • Kenmore Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hav to first check whether something is stuck in-between your outer and inner drum. Un-plug first. Is the basket moving smoothly, as in previous washes? If not, there could be something stuck, and the F51 reading could be correct - strain on motor.
You have to get in to the top of the washer. There are two clips that hold the front of the top in place - wedge a putty knife against these (hard) while pulling up to release the top. The top will then swing up as a piece. It is easier to undo the clips in the back allowing the whole top to swing completely back and away (having an extra person helps, you don't want to put pressure on the wiring harness between the base and the top). Next you have to unclip the cover all around the edges (lifting the tabs) and swing it back. Take a flashlight and inspect carefully the gap between and under the drum for any stray items, and remove them. Reverse the process to re-assemble.
You hv to rate me ‘very helpful’,
Posted on Jun 15, 2010
  • 367 Answers
I have heard if you keep bugging whirlpool somtimes they will send you the part for free.
Posted on Jan 15, 2009
F1 CODE ONSEARS ELITE OASIS WASHER MODEL #110.27032603 SER.#CU0670188
F then 1 flashes when there is a primary control failure. Replace the machine control assembly. The part number for the control board is W1018966
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Gene
Aug 15, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis hc 110.2708 washer do not work (power switch do not work) Power cable no problem)
You need to call (800) 659-7026 tell them your info and model and ser# and they will send someone out for free to replace the control board it's because it was the first year out and there is always kinks in first years don't worry it will be ok just think only one more week without a washer :)
Apr 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The Kenmore Elite Oasis has a code that flashes F1? What does the code F1 mean ?
Whirlpool produced this same washer for themselves and are doing a rework on it due to the same problem you are having with your Kenmore. Basically its having trouble gauging water fill and load size. The only real repair we are doing is changing the main control board and the wiring harness going down the back inner wall of the washer with differently programmed board and beefed up RPS on the wire harness. Call Sears and ask them what they plan to do to repair the unit they sold you. Explain to them you spoke with a tech and what I have told you and give them the chance to make good on the situation. I would say let them do the RIGHT thing, but then you would have been called when they found the issue about a year ago. And would have been offering the free upgrade to keep you as a customer.
Jan 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Have kenmore elite oasis, type 580. when starting
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hi! Can you help me decide if the Kenmore oasis 3.8pc is a good washing machine.
The Kenmore Oasis is made by Whirlpool for Sears. It is the same as the Whirlpool Cabrio. The Cabrio and the Oasis had a problem with the computer board. Whirlpool has been replacing the computer boards under a recall(mine was replaced recently). But I believe it is the model with no agitator in it. The one your talking about I believe is the one with the agitator. Whirlpool makes a good product. I would stay away from Maytag. Besides the recall problem I have had mine for over 2 years and it has worked fine. But I did get the extended warranty with it due to all the sensors and computer board can make repairs expensive.I have not had to use the extended warranty yet. My previous Kenmore washer was 12 years old and stopped working due to a rat chewed thru all the wiring and hoses. It would have cost me more to repair than what it was worth so I purchased the Cabrio.
Sep 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis Top Loader no spin and then some.
Apr 24, 2009 | Kenmore 27032
Washer fills and starts for a while and then stops
I recieved the followng letter from sears last week since we had registered our OASIS He washer two years ago since we purchased it new. The washer has a serial number that is authorized to get a replacement board, and the part has been shipped to my house. Once it arrives, we are to call the local Sears dept for someone to install the new board.
For washers that have the first four of the serial numbers as:
CS48-CS52 or CT01-CT49 qualify for the replacement Control Board.
1-800-847-9083 between 8am-8pm M-Saturday.
Good Luck all.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis washer will not turn on
I have the same problem. I used the unit 2 days ago and no problems- just bragged about the unit yesterday and now today it will not turn on and it is no longer under warranty. I also checked to see if power to plug and it is fine. Any suggestions?
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
Jan 13, 2008 | Kenmore Oasis HE 27082 Top Load Washer
F1 and F83 codes
Marsha, F1 is the code for a primary control failure. Since you just replaced main board check to see that all the harnesses are seated correctly. On this model I've found that if you have a pinched or blocked pressure tube,(hose going to the control board) it will give the same error code as a failed control board. Make sure it's not being pinched when replacing the consol. The F83 is the code for door unlock failure. You need to get past the main control board failure first...Catriver..post back.
Apr 20, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
133 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
