Question about Whirlpool Duet GHW9150P Front Load Washer
WASHER STOPS WORKING AND FLASHES 06 F
THE WASHER WILL STOP WORKING AND FLASH 06 F. I STARTED IT OVER AND IT DID THE SAME THING.
    President:
  • 373 Answers
F06
Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Posted on Jan 15, 2009
Washer stopped in mid wash. Clean light came on and flashes 7 times. Pressed clear went to 2 and finished. Pressed start light flashed 3 times won't start.
remove the bottom kick panel,you'll see a tech sheet there in the plastic bag,it will tell you how to check to see if the heater or board is bad,the light will flash 7 times,it's an error code telling you that there's a heat problem.
Feb 20, 2015 | Dishwashers
Kenmore elite he3 model 110 f-06 code comes on and washer stops .
I was getting a F-xx code can not remember the number.
If you remove the bottom front plate , I remember 3 three screws.Behind that is the filter for the machine, mine had a 2-3" white cap that came off with a screen inside that was plugged. When you open it up you can get a fair amount of water come out. The machine will not work until you put the front cover back on.
UNPLUG the machine FIRTS
Aug 23, 2012 | Kenmore Washing Machines
Whirlpool Duet GHW9400 PT4 on any of the cycles, runs 1/4 of the way through the was cycle and stops and starts flashing F 06, pushed cancel once then started the cycle again this worked for awhile. Then...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 16, 2009 | Whirlpool GHW9400 Duet Washer
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the MCU
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Washer HE3 and it stops - F and 06 flashes.
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Start with the obvious things that you can rule out first. Since your problem is intermittent at times, you may just have a loose or corroded connection between the Drive Motor and/or Main Control Unit. Check all your connections.
Another thing to try before delving too deep into troubleshooting is to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" for your washer. Sometimes these problems can easily be resolved by resetting the CCU to clear momentary glitches. If the problem reoccurs after a reset, then you have a genuine problem and will need to investigate further. The link I provided should give you the advice you need. If you still have questions, please let me know. I hope this helps you.
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F and then 06 error/ Kenmore elite HE 3T series 4
well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Service m6500 after last wash the start button contiues to flash unable to use washer even if power is turned of
My washer did the same until i relalised that after the wash when light is flashing, turn control to stop position and wait until it stops flashing before turning machine off. Sometimes i have to turn control right around again for it to stop flashing but this is how it works.
Dec 07, 2008 | Washing Machines
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal De
