Question about Mitsubishi Televison & Video
50" mitsubishi tv
One day it just turned off by itself and when you press the button to turn it on, it comes on and turns right back off.
Atech saiid transformer, get a new one, 3 to 500 for fix
Posted on Jan 16, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS 5047. Won't turn on. When the on switch is pushed it immediately turns itself off.
I had just put in about $500 worth of work into this TV to clean the color tubes of bacteria and other miscellaneous problems - They kept my TV for 3 months before bringing it back. It worked for 2 days and then everything went green, so they came back and took it for another 30 days before bringing it back.
This new problem could have been anything as simple as a tube to a circuitry problem. We decided to junk this Mitsubishi product. I have a 30 year old Curtis Mathis TV that I've never had any problems with (that's 3 times the age of the Mitsubishi).
We've opted for a new 50-inch Panasonic Plasma with the anti burn in technology. I will not buy another Mitsubishi product, or a rear projection TV of any brand after this experience.
Aug 17, 2008 | Televison & Video
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi tv
Could be a power supply problem - sounds like the feeder cap was failing slowly until the heat stress on the regulator finally gave out.. You'll want to check the following: Strm6515A (That's the regulator, R9a23 1.2 ohm, C9a15 220uf/35v , R9a0 1k all in that feed circuit for the regulator.
Bill
Jan 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV turns off right away relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50501 TV turns off by itself
First check see if timer is set to come on by going throu the menu. If not then check Service Menu by pressing Menu2357 and check in there for timer on or off
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
