Question about Dryers
Location of heating element
Heating element for frigidaire ''Crown'' model #cws3600asi
  • 333 Answers
The heater element on this washer ris behind the drum. You can change it from the rear or throught the top rear of the dryer. I hope this helps.
Posted on Jan 15, 2009
HOW DO I CHANGE THE HEATING ELEMENT OF THE FRIGIDAIRE RANGE
Good Afternoon JOES, thanks for your post!
I understand that you want to change the heating element on the inside of your Frigidaire range. In order to research and provide you accurate information I would need your model number. You can locate the model number on your serial tag which is located on the frame behind the lower drawer. With that information I can better assist you. -Matt
Mar 15, 2015 | Frigidaire Kitchen Ranges
Dryer is not producing heat
Good Morning friend, thanks for your inquiry!
I understand that your Frigidaire dryer is not producing heat. Have you checked the exhaust vent to assure there is not a build-up of lint blocking ventilation? If so clean out the lint and check to see if your appliance heats after that. It could also be a potential issue with your element or thermostat I would suggest seeking assistance from a technician for further diagnose. I hope this information helps. -Matt
Sep 28, 2014 | Frigidaire Dryers
A step by step video on who to find and change a heating element on a frigidaire crown dryer
Good morning friend, thank you for your post!
I see you are trying to change the heating element on your Frigidaire Crown dryer. I am unable to locate any video to assist in this replacement but I would advise that these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Jul 30, 2014 | Frigidaire Dryers
How to check heating elements in oven
Hello Friend, this is Z. Thank you for your inquiry!
I understand are seeking information on how to check the heating (bake/broil) elements in your Frigidaire oven. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step? Also, may I have your model number please? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side.
Jul 13, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Where is the heating element in frigidaire dryer
Hello - Typically speaking the element is located towards the bottom of the drum area. However, to better address may I please have the model number?
Jan 14, 2013 | Frigidaire GLER331A Electric Dryer
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
WHERE IS THE HEATING ELEMENT FOR A FRIGIDAIRE FER341ACO
it is located on the back inside of the dryer, here is a step by step:
http://www.ehow.com/how_4866523_fix-frigidaire-dryer-heating-elements.html
I do not know why you want to replace the element but if the problem is no heat then here is another website that can help,Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 19, 2011 | Frigidaire Electric Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The bottom of my frigidaire is not cooling properly; and the freezer works great; is it a minor problem i can fix
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Frigidaire FRT17G4B Top Freezer...
Dryers Logo
290 people viewed this question
Top Dryers Experts
