Question about InFocus LP 815 Multimedia Projector
System will not power up
Greetings , I have a LP-815 System that will not power up. Please Advise!
R.Askew
  • 74 Answers
If your not getting any leds, then your power supply is defective. I repair projectors. My ebay id is gtitubro
Posted on Aug 15, 2009
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
I need a diagram for the fuse box in my 1995 ford explorer
See Below.
Hope this helps.
Zeppelinx12
Fuse Panel, Explorer
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Feb 24, 2011 | Ford Explorer Cars & Trucks
BURNER CANNOT BE LOCATED
The drive may just be going bad but you can try to force your system to reinstall the software driver for it by deleting it and restarting your system. Sometimes this will force the OS to 'find' a 'new device' and reinstall the driver.
Mar 02, 2009 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
How can i increase my ram in intel desktop board 815
Hey,
Ram can not be increased as it is a hardware component in the computer, you can install more ram or upgrade the current ram modules that are inside the computer.
Feb 24, 2009 | Intel Motherboard
I have an Intermatic Model EJ500 and I keep getting No OP see inst. The lights won't come on even manually. Please advise.
This appears to be a known problem with this timer/switch. Contact Intermatic fo a possible free replacement. 815-675-7000 or http://www.intermatic.com
Jan 28, 2009 | Hardware & Accessories
Kenwood kvt 815
I NEED HELP TO UNLOCK A KENWOOD KVT 815 PLEASE HELP THANKS CHARLES
Jun 24, 2008 | Car Audio & Video
Vsx-815 steady blinking blue light
Hold "Enter" and "Advnc. Surrnd" buttons on receiver at the same time.
Dec 29, 2006 | Pioneer VSX-815-K Receiver
InFocus LP 815 Multimedia Projector Logo
67 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
