Question about Acer TravelMate 2300 Notebook
I have wireless sigal but cant connect - Acer TravelMate 2300 Notebook
  • spx09 May 11, 2010
    what means you cannot connect? if it doesn't connect when you push the connect button there may be a mac-address-lock in the router you're trying to connect to
  • BillW50 May 11, 2010
    Are you trying to connect to your own wireless router, or somebody else's?
Hello, My cable box don't have a place to connect an HMDI cable, my tv keeps saying weak Antenna sigal
what type cable does the box have that the tv has the same type connection but perhaps if you try rotating the antenna .. I use an antenna mounted 40 ft above my house and get many channels here.
Nov 14, 2015 | Televison & Video
Turn signals dose not work
Depending on the make model and year, the turn signals and emergency flashers should be on two different circuits.
Jul 18, 2013 | Cars & Trucks
Signal and hazard lights do not work fuse is good
It is usually located near the fuse boxunder the dash on the driver's side. Simple way to find is go buy a new one and ask the counter peson to show the diagram showing its location. Cheaper than have a mechanic do it.
Aug 18, 2012 | 2000 Ford Focus
Monotor no input sigal
check out the monitor cables if they are too old change them
Aug 12, 2012 | Dell Dimension E521 PC Desktop
Can this tv model do a wireless connection to my laptop? I have a wireless router - WGR614 Netgear, and an HP Pavilion entertainment PC. Thank you, Diane
Your computer is built to acquire wireless signals made possible with routers as link stations. Also, the computer is capable of transmitimng signals with the same process to any device with conditions explained. First, TVs would acquire wireless signals with builtin wireless routers to recognise external media requirng intergration. Performing sigal transmittion compartibility checks should produce results of whether your computer is capable of communicating with the computer at a wireless level. Refering to the TV user guide ascertain the wireless capabilities with respect to computer to TV media communications. Every possible signal connectivity is acquirable with performing technical diagnostic checks to ascertain the missing links. For example, modern devices are capable of transmittions across mediums achievable at the users own experimentation.
Good luck
Jan 08, 2011 | Televison & Video
I HAVE AN ACER LAPTOP WORKING OFF A LINKSYS ROUTER AND NOW WOULD LIKE TO ADD MY NEW TOSHIBA LAPTOP. HOW DO I DO THIS, KEEPING IN MIND THAT MY TOSHIBA IS NOT CONNECTED TO THE INTERNET
Make sure that the wireless is turned on, on the laptop. Then go to network settings and veiw wireless networks, or if your running xp double click on the wireless signal on the bottom right corner. Click on your wireless sigal and hit connect and that should be it.
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
Usb 2wireless adapter keep losing sigal
If your computer keeps losing the signal, you need to either change the wireless channel or boost your wireless power on your router. Sometimes even a combination of both is needed so you stop losing signal.
Feb 19, 2009 | 2wire 1000-200004-000 Network Adapter
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
