Question about Samsung TXN3071WHF 30" TV
No pic or sound
No pic (no light of any sort) when turn on. Set makes the noise that accompanies being turned on and the front red light beside the power button lights up. But that is it. No sound or other indications that the set is on.
    Problem Solver:
  • 7 Answers
All the TV's have a fail safe now a days. It looks like that there is a problem with color management or the picture tube. If this is a projection than I could have said that it is a certain that it is to do with the color management. When Tv tries turn on it get a signal that there is a problem when it does the diagnosis prior to turning on and it stops. I am leaning towards the Picture tube as you didn't mention that the power light goes off after it tries to turn on. Please get it checked. good luck.
Posted on Jun 18, 2007
SOURCE:
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
I have a PT50LC13 HDTV and it quit working today. The little red light on the front where it says lamp started flashing red and every time I tried to turn on my TV it made a noise. I just wanted to ma
From the info you gave, it does sound like the lamp is bad. The sound you hear is the ballast trying to ignite what used to be a lamp. The lamp is assessable throught a 6x6 cover usually in the rear of the set held on by usually two screws. After the cover is off ( with a flashlight ) locate the screws(2) that hold the lamp housing in, remove those and it should slide out. Make sure you unplug the set first and remember to reset the lamp timer witch is located in your owners booklet after your done with the set on.
Apr 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Samsung sp01 version
you have 4 blown capacitor on your powersupply
Jun 07, 2008 | Televison & Video
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
My 32in sdtv red power light,no pic no sound
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Oct 05, 2007 | RCA 32F531T 32" TV
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
Jerry Greenberg
Jerry Greenberg
Ekse
