Question about Nextar X3-03 Car GPS Receiver
GPS WON'T FINISH LOADING
OUR GPS WHEN TURNED ON WILL ONLY LOAD 3/4 THE WAY AND THEN TURN OFF... I WANT TO OPEN THE BACK AND REPLACE THE RECHARABLE BATTERY BUT HAVING PROBLEMS DOING SO CAN RECHARABLE BATTERIES GO BAD AND SHOULD I TRY AND REPLACE IT? OR IS THERE SOMETHING ELSE I CAN TRY..
THANKS FOR YOUR TIME AND HOPE TO HEAR FROM YOU SOON
KATHY
  • wk1990 Jan 16, 2009
    I HAVE TRIED YOU SUGGESTION SEVERAL TIMES BUT DID NOT WORK... THANK YOU ANYHOW
The battery ran down & I pluged it into my charger but it will not take a charge I tried to reset it but nothing happens
Posted on Feb 04, 2009
Hold down reset button for 3 secs. then hold down power button while holding reset button until the boot menu comes on the reboot or pick update os. note: u must 1st use reset button to choose the options the the power button...
Posted on Jan 16, 2009
Garmin won't switch off
Open unit disconnect battery and speaker wait 3-4 min Re connect battery while opened .This should reset and clear any faults. ..reassemble
Feb 06, 2013 | Garmin Edge 705 Handheld GPS Receiver
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
Whean I am goas to turn on my mobile Blackberry RIM 7290 that time mobile is showing TCU EXCEPTION RESET messege.What shoud I do for solve this problem.Pls help me.
Download and install the latest BlackBerry Device Software.
1. Download the latest version of BlackBerry Device Software from your wireless service providerxxx8217;s website.
2. Connect the BlackBerry device to your computer.
3. Open BlackBerry Desktop Manager and double-clickApplication Loader. The Application Loader Wizard opens. Click Next.
4. If prompted, enter your device password and clickNext. The Application Selection window appears.
5. Select the applications to be loaded on to the device, then click Next.
6. The Completing the Application Loader Wizard screen appears.Do not click Finish. Click Advanced to begin loading the applications.
7. In the Data Preservation window, select the Erase all application data and Erase all currently installed applications check box and clickNext.
8. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete.
9. Click Finish to begin the Application Loader Process. The data on the device is erased and reloaded.
10. Click Close when the loading operation is complete.
Mar 01, 2011 | RIM BlackBerry 7290
My Garmin Nuvi 1390 has frozen on the 'loading maps' page I turned the unit on holding down the bottom right hand corner clicked yes when asked do I really want to erase all user data. What if the device...
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Take care.
Jul 04, 2010 | Garmin nuvi 1390T Car GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
We went on vacation and turned off the water.
Turn on the water, unplug machine and plug it back in.
Sep 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 255w won't turn on and remain on
pull the surround off the front of the front of the gps. there should be a button under the plastic or look on the back and there should be a reset button that you can stick a pinhead into. if that doesnt work then your gps doesnt work and you need to replace.
Jun 13, 2009 | Garmin Nuvi 255 GPS Receiver
I cant get it to load
get out from under any roofs
tall buildings
micro towers
go to open spaces and restart
May 29, 2009 | Nextar Q3 GPS Receiver
OUR NEXTAR GPS WHEN LOADING WILL ONLY LOAD 3/4 THE WAY AND NEVER FINISH TO TURN ON
mines the same when loadind only 3/4 of way how do i fix this problem
Jan 15, 2009 | GPS
Nextar X3-03 Car GPS Receiver Logo
140 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
