Question about Kodak EasyShare CX6330 Digital Camera
New battery won't charge.
I bought a new rechargeable battery for my camera. It will not charge when I put it on the dock.
  • pmuscio Jan 17, 2009
    I have checked and rechecked the + and - on the battery.
  • 716 Answers
Remove The Battery And See If The Camera Will Turn On When Placed On The Dock.
If It Does Either Your Battery Is No Good Or Its Installed Wrong.
If It Doesn't Its The Dock To Camera Connection.
I Have This Camera And Dock Right Next To Me So I Know As Of Right Now The Camera Powers On Without The Battery In When Placed On The Charger.
Posted on Jan 17, 2009
  • 10,594 Answers
Please confirm that dock itself is ok and working fine by placing old battery and check does it show any sign of charging fr a while?
If dock is fine then new battery is suspected and should be tried on different dock to make sure that battery is bad.
Posted on Jan 15, 2009
    Brigadier General:
  • 5,158 Answers
Check that the battery is in the camera properly ... pay special attention to the plus and minus
Robert
    Top Expert:
  • Kodak Master
  • 77,499 Answers
You have checked the dock to make sure that the dock has voltage at the contacts that charge the camera?
  • yadayada
    yadayada Jan 15, 2009
    If u don't have a volt meter to test the dock go to a radio shack and ask them to test it, I am sure they will do it for free. If u do have a meter the voltage should be around 5-7 volts
  • yadayada
    yadayada Jan 17, 2009
    check the battery dock for correct DC voltage, should be 5-7 volts, or just buy another charging dock.
Hp photosmart M23: can I charge new batteries in the camera
The batteries can be recharged in the camera with the appropriate adapter or dock. See page 155 of the manual.
Oct 17, 2012 | Cameras
I got a dx4530 w/easyshare Dock II. from a friend of mine. He had been using AA batteries and it worked fine. I went to Best Buy and bought 2 Ni-MH batteries and put them in the camera. I then put the...
In the Kodak cameras of that vintage the original 3V rechargeable battery was made of 2 regular AA rechargeable batteries and a special piece of plastic that pushes some microswitch in the battery compartment. If this piece of plastic is missing, the dock would not charge the batteries. You either need the special CRV3 battery or to charge the normal AA rechargeables with a separate charger.
Sep 18, 2011 | Kodak EasyShare DX4530 Digital Camera
Kodak C340 I installed new batteries and docked it over night and the camera still dose not turn on
with new batterys you may find if quicker to charge them in a battery charger and not in the camera,,,the camera charger is for "topping up" the batterys realy not fully recharging them its so you can leave the camera on its docking port and it will have fully charged batterys in it when you wont to use it,, to fully charge a new set of batterys it could take days,,,,so overnight is to short a charge to recharge them,,,leave the camera on its docking station for a fuw days at least, or use a home charger for your type of battery ie:AAA or AA, both take 16 hours to recharg fully
Feb 16, 2010 | Cameras
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
May 12, 2009 | Kodak EasyShare DX4330 Digital Camera
Battery not charging
Hello June, This sounds pretty easy, I repair these cameras. It sounds like you have a problem with the adapter that plugs into the wall outlet. Remove the battery from the camera and plug the a/c adapter directly in to the camera and try to power on the camera,if it powers on then the problem is the dock,if it do not power on it is the a/c adapter.
Best Regards, Russell
Apr 27, 2009 | Kodak EasyShare DX7590 Digital Camera
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
When I put camera on docking it win,t show charge
First, the dock will charge only the batteries that came with the device; not other rechargeable batteries.
Be sure that the Kodak battery is inserted correctly, the door is closed securely, and that the camera is securely seated in the dock with the power cord secure to both the dock and the AC outlet. The USB cord does not supply power to the dock.
Hope this helps.
DigiChick
Jun 09, 2008 | Kodak EasyShare CX7330 Digital Camera
Kodak EasyShare CX6330 Digital Camera Logo
42 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
