Question about Aiptek A-HD 720P Flash Media Camcorder
Memory full message
When I first got the camera it would record for about 18 seconds before it said the memory card was full(without a memory card). So I bought a 2gb kodak memory card for it but when I put in the memory card after only 18 seconds it said the memory was full i don't know If it's the memory card or the camera? I have a normal 720p HD camcorder, but the same problem, I was recording a Warhammer game, and I went to stop the recording when it frozze, and when I did a hard reset (took the battery out then put it in again.), it said "memory full", and NONE of the buttons worked... and when I tried to format it, it said "format OK", but froze up. this was aftter I hard reset for 5 minutes.
    Genius:
  • 1,234 Answers
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    I have a problem with my 2 gig memory card. I can
    You need a class 6 or better card to record videos for any real length of time.
    Feb 17, 2010 | VuPoint DV-M5056-VP Digital Camera
    The unit keeps freezing up
    Take out memory stick from camera and check does it still freeze?
    I think memory card in camera is causing problem.
    Hope this info will help you.
    Dec 08, 2009 | Sony MHS-CM1 HD AVC Camcorder
    Is there a size limit for the memory card for the SD630. I put a 4 GB one in it, and it say memory card error
    This camera only supports up to 2GIG or memory card so that's the reason why the 4 GIG wont work with it....
    Jul 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
    Memory full message
    the problem Probably is that the memory card isn't the right kind, so it just records to the "Built in memory". The only way to fix this is to format the Memory card
    Aug 16, 2008 | Aiptek A-HD 720P Flash Media Camcorder
    Aiptek IS DV2
    Seems like its time to flush the contents of the memory card of camcorder to a computer.
    There's a limited amount of memory in every memory card. After constant recording, the memory  gets full and the recorded stuff needs to be either deleted or flushed (uploaded to a computer) to make room for newly recorded stuff.
    Unless you have a blank memory card, your problem should be solved by the above mentioned idea.
    Oct 20, 2007 | Aiptek IS-DV2 Camcorder
    SD Memory Cards to record in MPEG2
    To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
    Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
    SD Memory Cards
    Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
    SD Memory Cards
    Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
    Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
    Aiptek A-HD 720P Flash Media Camcorder Logo
    150 people viewed this question
    Top Aiptek Video Cameras Experts
    tomikles
    Level 1 Expert
    prouddad_1
    Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
