Question about HP OfficeJet 7310 All-In-One InkJet Printer
Officejet 7310, ADF will not operate, no movement of upper roller
Either copying or faxing the upper roller will not engage the paper. It simply doesn't move at all. I have tried the roller and pad cleaning tips in the manual. Also, reset the printer and reinstalled the printer software. Nothing has changed the problem still exists.
  • 837 Answers
Lift up the cover to the automatic feeder.
You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it.
Then you will be able to see of there is any jammed paper, which which can be pulled out carefully with a pair of tweezers.
Some may be under the rubber rollers.
Posted on Jan 15, 2009
My HP Officejet Pro L7780 faxes off & on. Motor is running w/in ADF, but the pick assembly does not grab paper
There should be a textured seperator pad, if that's worn out, replace it. Also check the ADF rollers should not be smooth. You may need to just replaced the ADF maintenance kit. It should include the roller assembly and seperator pad.
Jan 17, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Giving me scanner error then asks me to turn off and on but still comes up the same
try to open the ADF feeder the upper portion scanner that you use to send fax by pulling upward the cover then check for paper jam in the sensor,
Aug 07, 2011 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Top paper feeder roller rotates but does not draw in the paper
There is no replacement rollers available so, printer needs to be replaced.
Apr 08, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Auto Document Feeder sqeeks and groans
the problem is the cluthch that controls the feed roller, do not overdrive the the roller in the opposite direction it will damaged the mechanical clutch inside.
that is the one making the sound.
Jun 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 7310
Sounds like there is something going on with the paper sensor flag that resides in the top cover of the automatic document feeder. Need to make sure it is moving freely. It is spring loaded so it should move freely and spring back in to place. Sounds like your may be sticking in the up position after a few sheets. When the ADF lid is down these sensor flags should go in to holes in the bottom of the ADF. Hope this helps..
Inkworks
May 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJect 7310 Uses 2 Pieces of Paper when Printing Fax
Sounds like the feed rollers need to be cleaned or replaced.
Dec 03, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
317 people viewed this question
Ben Johnson
