Question about RCA JET S2002 MP3 Player
Sound only come out of one side
I just received this player for x-mas. The sound only comes out of the right side, the left side is completely silent. I have tested other headphones and know that isn't the problem.
Thanks, Jared
  • Anonymous Feb 24, 2009
    i got mine for christmas too and it was working fine and then one day only one side was working.
Take the player apart and take the board out and on the headphone jack there are 3 prongs push them down slightly should work.
Posted on Jan 16, 2009
Only the left side of my Blackweb Headphones work. What's the problem?
While they may be wireless, there is a cable that runs from one side to the controller on the other side. Check this cable to make sure there are no outward signs of damage.
Mar 19, 2017 | The Audio Players & Recorders
Sound seems to coming from only one of my front speakers(left side). what am i missing? I can't seem to find a balance setting on the menu
Traditional Balance Controls are gone with the dinosaurs of stereo audio equipment.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFR-700-Receivers-manual/id/582dj599/t/2/
You may just have a speaker or speaker wire loose/failing. Swap them to isolate to an internal or external failure.
There isn't enough adjustment in the setup to make any channel completely silent.
Use test tones to diagnose it. Page 36.
Apr 25, 2011 | Adcom GFR-700 Receiver
Left earbud completely silent.
Hi,what makes the left hear completely silent it because the wire inside the left side ear bud might have cut and it's not contacting with the speaker inside the ear bud.
What you will do is this, open the left ear bud that is not working, check if the connection is not properly fix. Also after checking if the wires are intact, if the wires inside are intact with no trace of cut inside,that means that the speaker inside is damaged and will need to be replaced..
If you can't do it your self, I would advice you contact a skilled personnel for help.
Thanks for using fixya....
Oct 21, 2010 | Shure (E2G) Consumer Headphones
Sounf come thru the right side but is silent in the left headphone
Hi,why sounds comes out from one side and the other side silentis because,the wire inside the speaker has cut and it needs to be soldered back with a soldering iron and a lead.
Sometimes it might also be from the speaker itself if it is damaged.
When you solder back the place that has cut,problem solved.
Oct 20, 2010 | Sennheiser HDR 120 Consumer Headphones
The left headphone is silent, no sound
Hello
if only one side is have a sound and one side is not, this is head phone wiring issues but ill let you know in this model the common defective is the headphone wire maybe this is open wire and not connected in to another chennel.
Angel
thanks...
Jul 29, 2009 | Aiwa Pavit AZ-HS128 (128 MB) MP3 Player
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
Sound only comes out of left channel, only dvd player works
I would Initialize Unit back to factory settings by turning off main power switch then hold both 6.1/7.1 surround and direct buttons ( they are next to each other near main power switch) in while turning un main power switch. Hold both buttons until you see all lights light up. Then check functions and setup like you bought it new.
Owners manual also explains how to initialize receiver
Feb 09, 2008 | Denon AVR-4800 Receiver
Audio only plays from left headphone
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
Nov 09, 2007 | Kingston Kpex100 Digital Media Player
Open Questions:
RCA JET S2002 MP3 Player Logo
82 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
