Question about GPS
Mines the same when loadind only 3/4 of way how do i fix this problem
Posted on Feb 10, 2009
Why does my Nextar gps system takes foprever to load when turn on
If it is running Win CE then it is VERY old. The GPS is probably failing to see the satelites. Probably time to replace it.
Aug 02, 2016 | Nextar w3g-01 3.5"" touchscreen portable...
My nextar x3b gps screen is frozen on loading
Aug 27, 2012 | Nextar X3B Car GPS Receiver
I cant get it to load
get out from under any roofs
tall buildings
micro towers
go to open spaces and restart
May 29, 2009 | Nextar Q3 GPS Receiver
Nextar GPS will not get past loading stage
Nextar will not assist in helping "fix" anything. Their solution is for you to send in the unit and they pitch it, send you one off the assembly line. I was able to get this unit working again in just GPS mode (what it was intended for), so using this workaround, you will lose the ability to use it as a tiny digital photo frame, MP3 player, etc.
I take no responsibility if you try this and "brick" your unit (render it unusable except as a $100 paper weight). BACK UP!!
1) Download and install ActiveSync from the Micro$oft website.
2) Connect the M3-04 unit to your computer
3) Turn it on
4) Red bar should fill and the M3-04 will "hang" in that screen, BUT viola it still connects to ActiveSync
5) Using Explorer from ActiveSync, navigate to ResidentFlash
6) Copy autorun.inf to your PC Desktop, make backup by renaming it to autorun.bak
7) Open autorun.bak with Notepad
8) Change the line to read without the quotes: "\ResidentFlash\Netropa Intellinav\IntelliNav.exe"
9) Save As to your desktop autorun.inf
10) Copy back to your ResidentFlash directory on the M3-04
11) Disconnect from PC and hit the reset button on back....BOOYA! Your GPS is functioning again.
Mar 19, 2009 | Nextar M3 Car GPS Receiver
hold down reset button for 3 secs. then hold down power button while holding reset button until the boot menu comes on the reboot or pick update os. note: u must 1st use reset button to choose the options the the power button...
Jan 15, 2009 | Nextar X3-03 Car GPS Receiver
X3-02 nextar gps
three step solution, easily correctable. wrap in towel, smash with ball peen hammer, gently lay in trash. You should have no more issues after this.
Mar 22, 2008 | GPS
Nextar HGPS35
I found this on Nextar support site. These units **** lots of problems being reported by many users.
Q: It (GPS) freezes on the "loading" screen. Why?
A: Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Jan 13, 2008 | Nextar X3B GPS Navigation System
Intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Jan 06, 2008 | Nextar Q3 GPS Receiver
Nextar x3-02
I just bought one P3. The SD card does not load the maps!!! I am going to return right away...
Dec 20, 2007 | Nextar X3B GPS Navigation System
GPS Logo
49 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
