Question about Creative Labs Inspire T6100 Computer Speakers
Less center speaker sound
I have bought 5.1 creative speaker and connected to dvd player (using proper jacks to connect 6 outputs from dvd player into 3 inputs for creative speakers) but i have less sound in center speaker than the front speakers .. pls help me in this concern
  • Anonymous May 08, 2009
    i have bought 5.1 creative speaker and connected to dvd player
    i have bought 5.1 creative speaker and connected to dvd player(using proper jacks to connect 6 outputs from dvd player into 3 inputsfor creative speakers) but i have less sound in center speaker than thefront speakers .. pls help me in this concern
I give two solutions
1. Buy Amplifier.
2. Buy stereo converter.
Posted on May 10, 2009
I have purchased creative T6160 5.1.It has 3 output jack.It's working fine with my PC.Now i want to connect with a DVD player.Please tell me, will it support by DVD player or which company's DVD...
I'm not sure I understand your question but, if you have an external DVD player, they probably will not work with it because you can't hook to the speakers directly. On the other hand, if you have a DVD player in your PC and your PC is capable, you can play DVD's through your PC. You may need software and if you want to play Bluray, you would need a Bluray player for your PC that, you may be able to add if your PC has an empty slotor, you could purchase an external USB player which will do either. Please clarify what you are trying to do.
Thanks,
Dave
Jun 05, 2011 | Creative Technology Creative Labs...
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
I instaled windows 7 but can't make work my inspire p5800 propely because works just 2 speakers from 5 not work center speaker and two other where is problem?
update sound card drivers
In sounds on control panel, check you have the sound ported to 5:1 or 6:1 speakers
Check you have the line out and other jacks connected properly
Jan 07, 2011 | Creative Labs Inspire P5800 Computer...
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
I bought a paramax p-510 I want to setup connect it to my tv, what cable do I need
i have no idea to connect it either. Specially since the AV has only 2 jacks instead of three. I connected the two jack with DVD, and the front 2 speakers work and the sub too, however i have no idea how to make the surround and center speakers work. I have tried various variations, but i think the thing is a fake made for only 20 bucks speakers without much juice.
I might be wrong but this is the first av with only two jacks instead of three, even the cable they provide has three jacks
Sep 22, 2009 | Audio Players & Recorders
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
Jan 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Creative Inspire 5200 speakers connecting to DVD player.
These are computer speakers, they will not work for a dvd player... Your dvd player has an rca/collex (SP) cable while your speakers have a 2.5 headphone style jack
Jan 03, 2009 | Creative Labs Inspire 5200 Computer...
Connecting Creative t6060 to my philips 5.1 dvd player
Hi Guys,
I am teh person who started this thread and I am happy to find the solution. The problem is not with Speaker but it is with DVD player. Infact it is not a problem, it is the setting which needs to be changed.
Go to the Setup menu and change the Speaker settings and set it to MultiChannel. This will give you sound to rear and center whenever it has to.
Hope this helps as it has to me.
Feb 25, 2008 | Audio Players & Recorders
Creative 5 in 1 speaker set up
buy jack to connect all the cables.
because computer are only two output audio terminal.
Oct 14, 2007 | Creative Labs FPS2000 Computer Speakers
Creative Labs Inspire  T6100 Computer Speakers Logo
248 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
