Question about Ruud Heating & Cooling
Inside rhe house unit is leaking water from around the pvc pipe.
"There is water coming from the bottom of the panel that is removable by that pipe. Not the pipe for overflow of the tray beneath the unit. I had trouble reading the model #.
    Champion:
  • 244 Answers
Cant understand what you are describing. is the drain pipe clear. water coming out end into french drain or pump. if not clear out by mechanical means or by blowing.
Posted on Jan 15, 2009
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
Tbx21ji refridgerator has water inside the bottom of fridge. it keeps happening
Mine did the same thing. Pull refrigerator out so that you can access the back. Take off lower dust cover , it's black and has several small screws. Once removed, you can see a pvc pipe running from top to bottom. Remove screw from clamp that holds pvc pipe vertical. Remove pvc pipe from top of refrigerator, then remove the top piece that was attached to pvc pipe. You may need to turn 1/4 turn counter clockwise to remove. Once removed, clean these 2 pieces thoroughly to remove any blockages. Install in reverse order and hopefully this fixes your water problem. This pvc pipe runs to a pan that water pools in and evaporates. If the water can't get here, it has to go somewhere.
Jul 12, 2013 | GE J Series 20.6 cu. ft. Top Freezer...
Drain inside house from a c is over flowing.central air
I am a certified HVAC Technician. I have worked in the field since 1996. I have seen this hundreds of times, if not a thousand times, in the past. Every central air conditioning and heat pump system comes with TWO drain pans, The MAIN drain pan is located within the AIR HANDLER (blower) UNIT, while the EMERGENCY DRAIN PAN is extremely LARGE and sits under the ENTIRE AIR HANDLER (blower) UNIT. The ONLY time water will be INSIDE an EMERGENCY DRAIN PAN is when the MAIN DRAIN PAN condensate drain line is CLOGGED, causing the MAIN DRAIN PAN to overflow. What causes the drains pans OR the drain lines to become clogged is slime and scale from the condensate water as well as debris from within the attic that may have either been blown by the air or may have simply have fallen into the emergency drain pan; or some insects from the out of doors have traveled up into the PVC Drain line and built a nest on the downward side of the P-trap. The P-trap is designed to prevent critters from entering your home through the PVC drain lines. Most CLOGS occur at the P-TRAP location.
The BEST thing to do is:
1. Locate the WHITE PVC drain pipe outside your house and ensure there is NO water draining from it.
2. Locate the same WHITE PVC drain pipe inside your house. You should notice a "TEE" where two WHITE PVC drain pipes merge into ONE WHITE PVC drain pipe.
Follow the below steps, in the order shown:
A. FIRST, find another person to act as your second set of eyes at the end of the WHITE PVC Drain Line that is located outside of your home. That person will be looking for water or debris to EXIT the end of that WHITE PVC DRAIN LINE.
B. SECONDLY, locate the WHITE PVC "P-TRAP" inside your house. It is normally located within a couple to three feet of your indoor air handing (blower) unit.
C. THIRDLY, very gently lift the entire WHITE PVC drain line up in the air as high as you can without breaking it, and slam it down onto the rafters or attic floor or garage floor. You are attempting to dislodge the CLOG within the drain pipe WITHOUT having to actually CUT the PVC and without damaging or breaking the WHITE PVC. Depending on how old the system is, it may or may not be brittle; and it may not take much to damage or break the PVC, which will cause leaks. So, be very careful at this point.
D. Ask the person outside if anything has started to EXIT. You can ALSO usually hear water start to drain if you put your ear up to the drain line. If the person said "NO"and if you don't see the water level getting LOWER in the EMERGENCY drain pan, then REPEAT step "C" above.
E. If the person informs you that there IS water now starting to exit the WHITE PVC DRAIN PIPE, you should then wait until all water has drained from the EMERGENCY DRAIN PAN; and then pour at least 1 quart of BLEACH down that drain, from the EMERGENCY DRAIN PAN exit. The BLEACH will further clear out any SLIME which may be remaining within the "P-TRAP" and will also CLEAN OUT and DISINFECT that drain line.
If the above steps do NOT work for you, then prepare to go into the next LOGICAL phase of your attack. Please NOTE: I am limited to 10,000 characters in my response, so I'll repost additional STEPS in another RESPONSE. Good Luck!!!
Sep 05, 2012 | Goodman CLQ36AR49 Air Conditioner
My Carrier AC is leaking from the inside connection to where the white PVC tubing connects to. The padding inside is soaked and when I press it, it is filled with water. It continuosly drips down water...
If this unit is new more than likely the condesate drain line does not have a deep U shaped "trap"in it. This allows the negative air pressure inside the unit to draw air up thru the drain line holding the water inside the cabinet until the fan shuts off, then the water can drop out of the unit everywhere.
If the system has been in foe some time and has the proper "trap" the drain line could be plugged any where there is a turn in the pipe. It is a messy clean out but it can be done by cutting the straight PVC pipe, right after the screw in fitting and the 90. This will allow you to unscrew the fitting at the unit and clean it out. Sometime there is a gel like clog that grows at this point. Then you can take a wire or compressed air to clean out the rest of the line to the outlet. Next pour hot water thru the PVC and see how it comes out the end. Worst case you will need to pour a solution of hot water and white vinegar to remove any build up.
Jul 29, 2011 | Carrier 38CKC042 Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
My 1042 Power Humidifier has water under the PVC pipe leading from the unit into the drain. Does that mean the unit itself is leaking water?
Hi, if the unit is leaking and it looks as though it is coming from the PVC pipe, more then likely its leaking at the unit its self where the pipe connects. Water will run down the pipe and drip down line. Dry it off and put your hand around where the PVC pipe screws into unit. Unless the pipe is cracked, this is where the leak is. If the fitting is a male or female threaded PVC fitting and a piece of PVC pipe that goes to the drain, you can repair this very easy. Just cut the pipe near the fitting with a hacksaw. Unscrew the fitting that goes to unit. Go to a hardware store like Home Depot, take the old fitting with you and buy a replacement. Buy a coupling, a small can of clear PVC glue and a small can or tube of pipe dope to put on the fitting threads. Screw the fitting in first and make sure it has pipe dope on it, get it tight with pliers. Take the pipe and coupling and glue it on the pipe. Put glue on the other end and slide it in the fitting that was where it was leaking before. Hold it in place for a few seconds. Once you put the glue on, be ready to put it together as it drys super fast and you cant take it apart once it sets. Very easy to repair and the parts cost pennys. Keep me posted. You can do this and will learn about plumbing! Good Luck.
Shastalaker7
Jan 24, 2010 | General Filters 1042-LH Humidifier
TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Nov 14, 2009 | Heating & Cooling
My panasonic cs-2470kr split air con is leaking condensate from the air unit. suspect drain blocked or tray broken. is it possible to remove the front cover to check it out. if so, how? Frank
Find the drain on the outside of the house (should be located near the condesing unit outside) it is pvc and as I said it should be near the outside unit. This pvc will be sticking out of the house to which you can take a wet/dry vac and hold it to the end of this pvc pipe and it should remove the algae that is clogging up your drain pan. This is the easiest way to unclog an a/c unit. Going to the inside of the furnance can be done using a wet/dry vac to remove the debris in the drain pan however, the clog could possibly be in the a/c condensate drain trap that is why I suggest going to the drain on the outside of the house and removing the clogg that direction.
Good luck on repairs.
Dave
Nov 09, 2009 | Heating & Cooling
A/C unit is working perfectly, but the past days is leaking water inside the house. Is probably the drain right?
Yes, the drain has either come loose, or clogged. Treat these as you would any plumbing problem. If the water isn't coming out at all where it normally does you can use some drain cleaner followe by plenty of water. If the line is broke you may need a 3/4 inch pvc coupling, pvc glue and a small hand saw to repair the drain pipe. There is a possibility that it is the pan has rusted through, which you would probably need help from a Pro. Good luck
Jul 13, 2009 | Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
