Question about Kirby Ultimate G Bagged Upright Vacuum
Belt replacement hi...well the belt is fine, its just that i can't figure out how its supposed to catch on to the hook thats connected to the handle that has the green and red arrows that say "belt on" and "belt off." the belt is just loose around the brush roll. the vacuum still works, it just doesn't seem right to have the belt on there if it's not "on" anything. how do i use the "belt on, belt off" handle to catch the belt so that it is actually "on" or "off" something?
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Posted on Jun 17, 2007
SOURCE:
NEED TO CHANGE A BELT
First you need to remove the metal cover to expose the brush roll assembly. Push up the plastic cover connected to the foot pedal to expose the motor shaft. Remove the brush roll assembly and simply hook the belt on the motor shaft first then pull back the brush roll and push the brush roll back to the slot. There's a small piece of plastic on the left hand side of the brush roll. This piece would go in after the brush is set in the slot. Finally, replace the metal cover.
Jun 23, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
opening in cleaner body. Reposition agitator making sure to
align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
I can't turn the belt off of my Kirby vacuum. I had the front off of it earlier to attach the hose, but now when I put the front back on, I can't get the belt to turn off. The lever twists about 3/4 of the...
turn the front part to the green so it is level and then twist the front to the red make sure the belt catch the hook as you twist it then if the belt is hooked just put it back on the vac like normal and lock it in place then twist it back to the green go postion
Aug 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I want to kill my kirby
Follow these instructions step by step and it should help with the problem...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Jun 20, 2009 | Kirby G4 Bagged Upright Vacuum
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Floor Attachment
Try this,
With the floor nozzle off the machine spin the belt lifter around until the red arrows match. If you look at the side that attaches to the vacuum you should be able to see the belt up on the hook. If is not on the hook offf the machine you will never get the belt on. Once the belt is on the hook attach the floor nozzle to the front of the machine. At this point you need to spin the belt lifter back to where the green arrows match. Oh and another suggestion make sure your hieght adjuster the pedals with arrows are all the way up. Hopefully that helps you out.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
231 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
