Question about Kenmore 98702 Stacked Washer/Dryer
Cold water pours in during final spin
I have a Kenmore stacked washer/dryer combo model number 417.98702891 (not sure of the year). When I run it through the regular cycle with the water set to Hot/Cold, it works perfectly. When I run the same cycle on Cold/Cold, it doesn't. It will fill and drain fine, spins at full speed, and the water shuts off when it is full.
The problem is that the final part of the cycle, the spin, it will pour water out while spinning thus making the clothes wet when it is done (occasionally the tub will be partially full at the end of the cycle). If I switch the water from Cold/Cold to Hot/Cold during this final spin, the water will turn off and it will function normally. It does this for all cycle settings.
At first I suspected the timer was bad, but I now suspect it is the cold water inlet valve. However, if it is the cold water inlet valve, why would it work fine throughout the cycle except during the final spin?
  • 15,935 Answers
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
228 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
