Question about Belkin Universal UPS UPS System
Need help diagnosing dead UPS
I have a Belkin F6C120-UNV. The symptom is that there is no power from the battery backed outlets. There are also no indicator leds on. When the unit is unplugged and I press the power-on button for several seconds I get a quick beep and the "ON Battery" led flashes very briefly. I have left the unit charging with no load for several days with no change. I opened the case to measure battery voltages and measured 8 volts on one and .4 volts on the other. I'm sure these voltages indicate problems with the batteries, but would this also explain why none of the indicator leds are working? If the problem is most likely only the batteries I would probably replace them but if there's some other problem as well I'll probably scrap the unit. Can someone suggest other troubleshooting I should do? Is it worth trying to charge the batteries with a car battery charger? Other suggestions appreciated.
  • Robert Meushaw Jun 17, 2007
    Your suggestion reminded me that I had several 12V batteries from an electric wheelchair. I hooked them up and the UPS seemed to work fine. Thanks very much. Do you have any suggestions for brands of replacement batteries, or doesn't it make much difference?
  • 883 Answers
Very likely, "would this also explain why none of the indicator leds are working?"...the dead batteries are your problem. you can try this test, since you had it opened: 1.) disconnect internal batteries, label the wires by terminal location. 2.) connect (2) 12 volt car batteries to same exact wires that you just disconnected, noting correct polarity. 3.) power up UPS. if everything ok, then buy 2 replacement batteries for UPS. if not ok, buy new UPS after through search inside UPS reveals no blown fuses or other faults including poor wire connections.
Posted on Jun 17, 2007
  • Marty marty Jun 18, 2007
    I've had good luck with Panasonic and Exide.
SOURCE:
BELKIN UPS FAULT
Need good batteries. Then press and hold the power-on button until the magnetic relay is on.
Nov 26, 2013 | Belkin (F6C800-UNV-PL) UPS System
BELKIN UPS DOES NOT WORK
If the device is over a few years old, then the batteries are probably dead. If so, they can be replaced. Below link shows some photos of the device once opened.
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
Does it matter if i use a 5 or 5.5AH replacement battery with my F6C900-UNV
you should only use the previous battery model or power of your ups bec..
it helps to work it for long time
Jan 31, 2012 | Belkin (f6c900-unv) UPS System
What doies it mean if the unit turns itself off, resulting in a loss of power to my electronics?
Most likely your battery is dead in the UPS. Replace the battery if you can. Belkin should be able to help you with that.
Mar 14, 2011 | Belkin 900VA ( F6C900-UNV ) UPS System
How to connect ups to a computer?
You have output sockets at the back of your UPS. Connect your PC power input from one of these outlets and switch the ups on.
Aug 14, 2010 | Belkin (F6C800-UNV-PL) UPS System
Need a schematic for a belkin F6C120-unv. All functions of the unit work fine other than the charging circuit won't keep the batteries charged. Runs about 24.7 volts, but keeps getting lower as the...
When batteries discharge during ac power it could indicate charger failure or micro failure or some other wierdness. makers do not release cd info. The best thing is.. buy another one as they can be very difficult to repair and of course they are dangerous, batteries are always live, waiting to bite you. I have worked on and repaired such circuits as the AP 200 series resonant converter and selling and hiring UPS for a long time. Beyond the simple easy checks youhave done the time it takes to understand how they work can better be used.
Sep 22, 2009 | Belkin Enterprise (F6C1200-UNV)...
Belkin F6C120 UPS problem, won't test
Check the manufacturer's web site for upgraded software on your UPS. This sounds more like a software problem.
May 28, 2008 | Belkin (F6C800-UNV-PL) UPS System
My model FC6120-unv is dead
If you've got nothing my guess is its something more than the battery as it should still be able to draw power if its plugged in. If its within the warranty period (3 yrs, I believe). Go to the belkin webpage and to their ups support and start the process to return it and get it fixed/replaced. A couple months ago I had a F6C500-UNV that suddenly died on me just like yours - no nothing. It cost me $13.00 or so bucks to ship the broken unit to Belkin; a week or two later I got a brand spankin' new F6C550 or whatever they currently sell in that same voltage area back from them. The cost to RMA the broken unit was much cheaper than even buying a new battery for the old and now discontinued unit.
Dec 26, 2007 | Belkin ( F6C500-UNV) (Bundle)...
Belkin Universal UPS UPS System Logo
566 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
